Trying to install JetPack-L4T-3.2-linux-x64_b196 on host PC but wont install CUDA. End of error message below:
Please help!
Please help!
Ign:109 Index of /ubuntu xenial-security/multiverse arm64 Packages
Fetched 570 kB in 8s (63.7 kB/s)
Reading package lists…
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
cuda-toolkit-9-0 : Depends: cuda-samples-9-0 (>= 9.0.252) but it is not going to be installed
Depends: cuda-documentation-9-0 (>= 9.0.252) but it is not going to be installed
Depends: cuda-visual-tools-9-0 (>= 9.0.252) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Get:1 file:/var/cuda-repo-9-0-local InRelease
Ign:1 file:/var/cuda-repo-9-0-local InRelease
Get:2 file:/var/cuda-repo-9-0-local Release [574 B]
Hit:4 Index of /bladerf/bladerf/ubuntu xenial InRelease
Hit:8 Index of /ettusresearch/uhd/ubuntu xenial InRelease
Hit:9 Index of /ubuntu xenial InRelease
Hit:11 Index of /gqrx/gqrx-sdr/ubuntu xenial InRelease
Get:5 Index of /ubuntu xenial InRelease [247 kB]
Hit:12 Index of /myriadrf/drivers/ubuntu xenial InRelease
Hit:13 Index of /myriadrf/gnuradio/ubuntu xenial InRelease
Get:6 Index of /ubuntu xenial-updates InRelease [109 kB]
Get:7 Index of /ubuntu xenial-backports InRelease [107 kB]
Get:10 Index of /ubuntu xenial-security InRelease [107 kB]
Get:14 Index of /ubuntu xenial/multiverse Sources [179 kB]
Get:15 Index of /ubuntu xenial/main Sources [868 kB]
Get:16 Index of /ubuntu xenial/universe Sources [7,728 kB]
Get:17 Index of /ubuntu xenial/restricted Sources [4,808 B]
Get:18 Index of /ubuntu xenial/main amd64 Packages [1,201 kB]
Get:19 Index of /ubuntu xenial/main i386 Packages [1,196 kB]
Ign:20 Index of /ubuntu xenial/main arm64 Packages
Get:21 Index of /ubuntu xenial/main Translation-en_GB [426 kB]
Get:22 Index of /ubuntu xenial/main Translation-en [568 kB]
Get:23 Index of /ubuntu xenial/main amd64 DEP-11 Metadata [733 kB]
Get:24 Index of /ubuntu xenial/main DEP-11 64x64 Icons [409 kB]
Get:25 Index of /ubuntu xenial/restricted amd64 Packages [8,344 B]
Get:26 Index of /ubuntu xenial/restricted i386 Packages [8,684 B]
Get:27 Index of /ubuntu xenial/restricted Translation-en_GB [2,556 B]
Get:28 Index of /ubuntu xenial/restricted Translation-en [2,908 B]
Get:29 Index of /ubuntu xenial/restricted amd64 DEP-11 Metadata [186 B]
Get:30 Index of /ubuntu xenial/universe amd64 Packages [7,532 kB]
Get:31 Index of /ubuntu xenial/universe i386 Packages [7,512 kB]
Ign:32 Index of /ubuntu xenial/universe arm64 Packages
Get:33 Index of /ubuntu xenial/universe Translation-en_GB [3,040 kB]
Get:34 Index of /ubuntu xenial/universe Translation-en [4,354 kB]
Get:35 Index of /ubuntu xenial/universe amd64 DEP-11 Metadata [3,410 kB]
Get:36 Index of /ubuntu xenial/universe DEP-11 64x64 Icons [7,448 kB]
Get:37 Index of /ubuntu xenial/multiverse amd64 Packages [144 kB]
Get:38 Index of /ubuntu xenial/multiverse i386 Packages [140 kB]
Ign:39 Index of /ubuntu xenial/multiverse arm64 Packages
Get:40 Index of /ubuntu xenial/multiverse Translation-en_GB [88
1 kB]
Get:41 Index of /ubuntu xenial/multiverse Translation-en [106 kB]
Get:42 Index of /ubuntu xenial/multiverse amd64 DEP-11 Metadata [63.8 kB]
Get:43 Index of /ubuntu xenial/multiverse DEP-11 64x64 Icons [230 kB]
Get:44 Index of /ubuntu xenial-updates/multiverse Sources [8,404 B]
Get:45 Index of /ubuntu xenial-updates/main Sources [305 kB]
Get:46 Index of /ubuntu xenial-updates/universe Sources [203 kB]
Get:47 Index of /ubuntu xenial-updates/restricted Sources [2,524 B]
Get:48 Index of /ubuntu xenial-updates/main amd64 Packages [775 kB]
Get:49 Index of /ubuntu xenial-updates/main i386 Packages [713 kB]
Ign:50 Index of /ubuntu xenial-updates/main arm64 Packages
Get:51 Index of /ubuntu xenial-updates/main Translation-en [321 kB]
Get:52 Index of /ubuntu xenial-updates/main amd64 DEP-11 Metadata [319 kB]
Get:53 Index of /ubuntu xenial-updates/main DEP-11 64x64 Icons [224 kB]
Get:54 Index of /ubuntu xenial-updates/restricted amd64 Packages [7,560 B]
Get:55 Index of /ubuntu xenial-updates/restricted i386 Packages [7,524 B]
Get:56 Index of /ubuntu xenial-updates/restricted Translation-en [2,272 B]
Get:57 Index of /ubuntu xenial-updates/restricted amd64 DEP-11 Metadata [157 B]
Get:58 Index of /ubuntu xenial-updates/universe amd64 Packages [627 kB]
Get:59 Index of /ubuntu xenial-updates/universe i386 Packages [577 kB]
Ign:60 Index of /ubuntu xenial-updates/universe arm64 Packages
Get:61 Index of /ubuntu xenial-updates/universe Translation-en [252 kB]
Get:62 Index of /ubuntu xenial-updates/universe amd64 DEP-11 Metadata [246 kB]
Get:63 Index of /ubuntu xenial-updates/universe DEP-11 64x64 Icons [331 kB]
Get:64 Index of /ubuntu xenial-updates/multiverse amd64 Packages [16.4 kB]
Get:65 Index of /ubuntu xenial-updates/multiverse i386 Packages [15.5 kB]
Ign:66 Index of /ubuntu xenial-updates/multiverse arm64 Packages
Get:67 Index of /ubuntu xenial-updates/multiverse Translation-en [8,344 B]
Get:68 Index of /ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,964 B]
Get:69 Index of /ubuntu xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
Get:70 Index of /ubuntu xenial-backports/main Sources [3,436 B]
Get:71 Index of /ubuntu xenial-backports/universe Sources [5,820 B]
Get:72 Index of /ubuntu xenial-backports/main amd64 Packages [4,844 B]
Get:73 Index of /ubuntu xenial-backports/main i386 Packages [4,836 B]
Ign:74 Index of /ubuntu xenial-backports/main arm64 Packages
Get:75 Index of /ubuntu xenial-backports/main Translation-en [3,220 B]
Get:76 Index of /ubuntu xenial-backports/main amd64 DEP-11 Metadata [3,324 B]
Get:77 Index of /ubuntu xenial-backports/main DEP-11 64x64 Icons [29 B]
Get:78 Index of /ubuntu xenial-backports/restricted amd64 DEP-11 Metadata [194 B]
Get:79 Index of /ubuntu xenial-backports/universe amd64 Packages [7,400 B]
Get:80 Index of /ubuntu xenial-backports/universe i386 Packages [7,080 B]
Ign:81 Index of /ubuntu xenial-backports/universe arm64 Packages
Get:82 Index of /ubuntu xenial-backports/universe Translation-en [3,996 B]
Get:83 Index of /ubuntu xenial-backports/universe amd64 DEP-11 Metadata [5,084 B]
Get:84 Index of /ubuntu xenial-backports/universe DEP-11 64x64 Icons [2,717 B]
Get:85 Index of /ubuntu xenial-backports/multiverse amd64 DEP-11 Metadata [216 B]
Get:86 Index of /ubuntu xenial-backports/multiverse DEP-11 64x64 Icons [29 B]
Get:87 Index of /ubuntu xenial-security/multiverse Sources [2,120 B]
Get:88 Index of /ubuntu xenial-security/main Sources [122 kB]
Get:89 Index of /ubuntu xenial-security/universe Sources [65.0 kB]
Get:90 Index of /ubuntu xenial-security/restricted Sources [2,116 B]
Get:91 Index of /ubuntu xenial-security/main amd64 Packages [491 kB]
Get:92 Index of /ubuntu xenial-security/main i386 Packages [437 kB]
Ign:93 Index of /ubuntu xenial-security/main arm64 Packages
Get:94 Index of /ubuntu xenial-security/main Translation-en [212 kB]
Get:95 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [67.7 kB]
Get:96 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [68.0 kB]
Get:97 Index of /ubuntu xenial-security/restricted amd64 Packages [7,224 B]
Get:98 Index of /ubuntu xenial-security/restricted i386 Packages [7,224 B]
Get:99 Index of /ubuntu xenial-security/restricted Translation-en [2,152 B]
Get:100 Index of /ubuntu xenial-security/restricted amd64 DEP-11 Metadata [200 B]
Get:101 Index of /ubuntu xenial-security/universe amd64 Packages [347 kB]
Get:102 Index of /ubuntu xenial-security/universe i386 Packages [300 kB]
Ign:103 Index of /ubuntu xenial-security/universe arm64 Packages
Get:104 Index of /ubuntu xenial-security/universe Translation-en [130 kB]
Get:105 Index of /ubuntu xenial-security/universe amd64 DEP-11 Metadata [107 kB]
Get:106 Index of /ubuntu xenial-security/universe DEP-11 64x64 Icons [147 kB]
Get:107 Index of /ubuntu xenial-security/multiverse amd64 Packages [3,464 B]
Get:108 Index of /ubuntu xenial-security/multiverse i386 Packages [3,624 B]
Get:110 Index of /ubuntu xenial-security/multiverse Translation-en [1,744 B]
Get:111 Index of /ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [212 B]
Get:112 Index of /ubuntu xenial-security/multiverse DEP-11 64x64 Icons [29 B]
Err:20 Index of /ubuntu xenial/main arm64 Packages
Err:50 Index of /ubuntu xenial-updates/main arm64 Packages
Err:74 Index of /ubuntu xenial-backports/main arm64 Packages
Err:93 Index of /ubuntu xenial-security/main arm64 Packages
Fetched 570 kB in 8s (64.1 kB/s)
cuda-cross-aarch64-9-0 : Depends: g+±aarch64-linux-gnu but it is not installable
@txbob can somebody please reply?
You might want to ask this on the Jetson forums.
