When installing “Create XR” 2022-2-0-rel.1
(ERROR is in the image below)…
_Glen Whelden
Sr. Technical Illustrator
Alert Innovation
_Glen Whelden
Alert Innovation
Hello @glen.whelden! I believe this is a firewall issue. You can go to this link to see the firewall endpoints that need to be accessible: Firewalls — Omniverse Launcher documentation
If that isn’t the issue, can you attach a copy of your Launcher logs from here: C:\Users\<USERNAME>\.nvidia-omniverse\logs\launcher
I found the culprit… the VPN. With the VPN on - Create XR, Navigator, and USD View wouldnt install. As soon as I took the VPN off, they installed perfectly…
