When i try to build my project on a 64 bit Windows 7 using VS 2010 in Debug 64 bit configuration I get this error along with two other errors.
error: linkage specification is incompatible with previous “hypot” in math.h line 161
error: linkage specification is incompatible with previous “hypotf” in math.h line 161
error: function “abs(long long)” has already been defined in math_functions.h line 534
I do not get these errors in the 32 bit build. Also, the 64 bit build worked in VS2008. Is there a proper work around to this problem or should I just wait till nvcc supports VS 2010 compiler?
