NEVERMIND. Fixed my problem (see next post)
Hello all,
I am trying to create a wrapper to do cula functionality. I am currently on a simple hello world cuda program and am trying to call the program from my .F90 code.
This is what I have so far:
in my .F90 code i have (NOTE that without the below call everything compiles fine.):
call testcu()
testcu is in file update_slabCU.cu, which is this
* @file update_slabC.c
* @brief C function for updating a slab (initial phase for LUD on cuda).
* @remarks this file is intended for testing C functionality
* which eventually will be used to intiate CUDA.
#include <aio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <errno.h>
#include <unistd.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include "update_slabCU.h"
#include <time.h>
#include <strings.h>
#include <cuda.h>
void testcu_(void)
printf("Hello World CUDA\n");
void update_slabcu_(int num_rows, int left_mcol, int * left_slab, int lda, int upd_mcol, int * upd_slab, int ldp, int this_image) {
printf("Hello World\n");
I have a update_slabCU.h file as well, which is this:
#ifndef update_slabCU_H
#define update_slabCU_H
extern "C" void update_slabcu_(int num_rows, int left_mcol, int * left_slab, int lda, int upd_mcol, int * upd_slab, int ldp, int this_image);
extern "C" void testcu_(void);
#endif
Here is the basic Makefile that has been created:
The makefile successfully compiles cudastuff, and the .o is placed in the fortran compilation area
Note: CC = nvcc, and FC = gfortran
.SUFFIXES: .F90 .c .cu
all: cudastuff $(OBJS) $(LIB_NAME)
cudastuff:
.cu.o:
$(CC) $(CFLAGS) $(CPRE) -c $< -o $@ -I./
$(LIB_NAME): $(OBJS)
ar cru $(LIB_NAME) $(OBJS); cp $(LIB_NAME) ../../../Lib/$(LIB_NAME)
cp *.mod ../../Modules/
cd ../../../Lib; ar cru libooclud.a ../Src/LUD/Objs/*.o
.F90.o:
$(FC) update_slabCU.o -L /usr/local/cuda/lib -I /usr/local/cuda/include - lcuda -lcudart -lstdc++ $(FFLAGS) $(FPRE) $(FDEBUGFLAGS) -c $< -o $@ $(MODINC)../../Modules
.c.o:
clean:
@echo '|--- Cleaning LUD/Objs Directory ---|'
rm -f $(OBJS) $(MODS) *.i
@echo '|--- Cleaning Modules Directory ---|'
cd ../../Modules; rm -f $(MODS)
@echo '|--- Cleaning Lib Directory ---|'
@rm -f $(LIB_NAME)
cd ../../../Lib; rm -f $(LIB_NAME)
Here is the error that I am getting when compiling:
Any help would be greatly appreciated.
Let me know if you need to see any more information.
ALSO:
I am using
and
