error LNK2019: unresolved external symbol "void __cdecl kernel(float,float,float,float,float,fl
Hey everyone,
I’m still getting the hang of CUDA, and I am currently writing my first proper program in it, but when I have made the kernel, I try to compile it and get the following two errors:
Error 1 error LNK2019: unresolved external symbol “void __cdecl kernel(float,float,float,float,float,float)” (?kernel@@YAXMMMMMM@Z) referenced in function main main.cu.obj GPMAD Cuda Section
Error 2 fatal error LNK1120: 1 unresolved externals C:\Users\hamnett\Desktop\GPMAD Cuda Section\x64\Debug\GPMAD Cuda Section.exe GPMAD Cuda Section
The kernel is shown as a prototype at the top of the code as such:
__global__ void kernel(float x, float p_x, float y, float p_y, float t, float p_t);
and is mentioned in main() as this:
unsigned int num_threads = 256; //The number of threads per block
	unsigned int num_blocks = no_particles/num_threads; //The number of blocks
	dim3  grid( num_blocks, 1, 1);
	dim3  threads( num_threads, 1, 1);
	//Execute kernel
	kernel<<<grid,threads>>>(*device_particle_x, *device_particle_p_x, *device_particle_y, *device_particle_p_y, *device_particle_t, *device_particle_p_t);
and finally, the actual kernel code is this:
//This is the kernel
__global__ void kernel(float* x, float* p_x, float* y, float* p_y, float* t, float* p_t) {
	const unsigned int tid = blockIdx.x * blockDim.x + threadIdx.x;
	//Define the transport matrix R
	float R[6][6] = {0}; //initialise the transport matrix R to all zero values
	float Beta = 0.8; //Assign a value to relativistic Beta (Obviously this will be determined by program at a later stage)
	float Gamma = 1.666; //As above for relativistic Gamma
	float L = 100.0; //Length of the drift space
	//To start with, we need to change the value of R to match a purpose, as at the moment it is set to all zeros
	//For now, we will make it equal to the drift matrix
	for(int j = 0; j < 5; ++j){ //Remember that the first matrix element begins at zero so the last is the 5th element
		R[j][j] = 1.0; //Sets the diagonals to 1
	R[1][0] = R[3][2] = L;
	R[5][4] = L/(Beta*Beta*Gamma*Gamma);
	//Now we need to create temporary variable arrays to store the results before returning them to the host
	float X, P_X, Y, P_Y, T, P_T;
	//Perform Matrix Multiplication of R matrix with particle elements for this thread index
	X = R[0][0]*x[tid] + R[1][0]*p_x[tid] + R[2][0]*y[tid] + R[3][0]*p_y[tid] + R[4][0]*t[tid] + R[5][0]*p_t[tid];
	P_X = R[0][1]*x[tid] + R[1][1]*p_x[tid] + R[2][1]*y[tid] + R[3][1]*p_y[tid] + R[4][1]*t[tid] + R[5][1]*p_t[tid];
	Y = R[0][2]*x[tid] + R[1][2]*p_x[tid] + R[2][2]*y[tid] + R[3][2]*p_y[tid] + R[4][2]*t[tid] + R[5][2]*p_t[tid];
	P_Y = R[0][3]*x[tid] + R[1][3]*p_x[tid] + R[2][3]*y[tid] + R[3][3]*p_y[tid] + R[4][3]*t[tid] + R[5][3]*p_t[tid];
	T = R[0][4]*x[tid] + R[1][4]*p_x[tid] + R[2][4]*y[tid] + R[3][4]*p_y[tid] + R[4][4]*t[tid] + R[5][4]*p_t[tid];
	P_T = R[0][5]*x[tid] + R[1][5]*p_x[tid] + R[2][5]*y[tid] + R[3][5]*p_y[tid] + R[4][5]*t[tid] + R[5][5]*p_t[tid];
	//Now bring the values from our temporary variables back into the ones used in the original kernel
	x[tid] = X;
	p_x[tid] = P_X;
	y[tid] = Y;
	p_y[tid] = P_Y;
	t[tid] = T;
	p_t[tid] = P_T;
Any suggestions would be greatly appreciated, many thanks
Forgot to mention, also I used CUDA_VS_Wizard_W64.2.2.beta2 by kyzhao and friends to build projects
I have narrowed the problem down to being in the actual call of the kernel, as commenting out the prototype declaration or the actual kernel code made no difference.
I have also found lots of similar problems which state that the problem was that library cudart.lib was not included. I have double checked and it is included for me, along with cutil64D.lib
Other than that I cannot see any difference between my build configuration and that of some working code…
Solved it myself now, for anyone who ever gets the same error themselves. I had made a function declaration for the kernel, which was not appropriate, so if I put the entire kernel definition at the top then everything worked.
