Network: grounding_dino
Tag: nvcr.io/nvidia/tao/tao-toolkit:5.5.0-pyt
Config (could not upload the file):
dataset:
batch_size: 4
max_labels: 50
test_data_sources: null
train_data_sources:
image_dir: /root/workspace/german-plates-roboflow/train/
json_file: /root/workspace/german-plates-roboflow/annotations/odvg/train_only_license_cont_id_odvg.jsonl # odvg format
label_map: /root/workspace/german-plates-roboflow/annotations/odvg/train_only_license_cont_id_odvg_labelmap.json
val_data_sources:
image_dir: /root/workspace/german-plates-roboflow/val/
json_file: /root/workspace/german-plates-roboflow/annotations/contiguous_ids/val_only_license_cont_id.json # category ids need to be contiguous
workers: 4
model:
dec_layers: 6
dropout_ratio: 0
enc_layers: 6
num_feature_levels: 4
num_queries: 900
num_select: 300
pretrained_backbone_path: null
use_dn: true
results_dir: /root/workspace/experiments/exp_0/
train:
activation_checkpoint: true
distributed_strategy: ddp
# is_dry_run: true
num_epochs: 10
num_gpus: 1
num_nodes: 1
optim:
lr: 0.0002
lr_backbone: 2.0e-05
lr_steps:
- 10
precision: fp32
validation_interval: 1
val_interval: 1
# verbose: true
Running the training from this container directly, no apt updates, pulled unmodified.
(Hydra) gives the following error:
UserWarning:
'jupyter_cfg.yaml' is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/automatic_schema_matching for migration instructions.
_run_hydra(
Error merging 'jupyter_cfg.yaml' with schema
Cannot merge DictConfig with ListConfig
full_key:
object_type=ExperimentConfig
Morganh
September 10, 2024, 3:53pm
2
Can you share the command line?
Within the container,
grounding_dino train -e cfg.yaml
Morganh
September 11, 2024, 1:57am
4
Could you please set absolute path for cfg.yaml and retry?
grounding_dino train -e /absolute/path/to/cfg.yaml
Error persists with a full path, or when I put the config to a default config dir:
grounding_dino train -e /root/workspace/jupyter_cfg.yaml
full_key:
grounding_dino train -e /usr/local/lib/python3.10/dist-packages/nvidia_tao_pytorch/cv/grounding_dino/experiment_specs/jupyter_cfg.yaml
full_key:
@Morganh
Morganh
September 11, 2024, 8:34am
6
Please make sure the yaml file is available.
You can use -v /localfolder:/dockerpath
when you run docker run
It is available. It is physically in the container
@Morganh
Morganh
September 11, 2024, 8:53am
8
Error persists:
grounding_dino train -e $SPECS_DIR/jupyter_cfg.yaml results_dir=$RESULTS_DIR
Then, after su taotoolkituser
drwxrwxr-x 3 taotoolkituser taotoolkituser 4.0K Sep 11 09:06 experiments
-rw-r--r-- 1 taotoolkituser taotoolkituser 1.2K Sep 11 09:06 ttku_cfg.yaml
-rw-r--r-- 1 taotoolkituser taotoolkituser 45M Sep 11 09:01 german-plates-roboflow.tgz
-rw-r--r-- 1 taotoolkituser taotoolkituser 1.2K Sep 11 09:01 jupyter_cfg.yaml
drwxr-xr-x 8 taotoolkituser taotoolkituser 4.0K Sep 4 12:30 german-plates-roboflow
and
grounding_dino train -e /home/taotoolkituser/ttku_cfg.yaml results_dir=/home/taotoolkituser/experiments/e0/
Error merging 'ttku_cfg.yaml' with schema
full_key:
Error persists @Morganh
Morganh
September 11, 2024, 9:57am
10
Thanks, that resolved the issue. Did not notice the typo :/
system
Closed
September 25, 2024, 11:09am
12
