Error Message: /docker_validation_example
@stma85 is getting a “/docker_validation_example” error message as screenshotted. Can someone assist?
Hi
The error is pointing to Clara train v2 released over 3 years ago. Since then we upgraded the TF to in v3 then v3.1 (which was deprecated last year). Since then in V4 last year, we moved the frame work to use Pytorch using Monai. We recently updating the code in v4.1 (last April to use monai 0.8
Can you upgrade to train v4.1 ?
