Error Message for cudaMemcpy
worker1 = (unsigned char ) malloc(sizeof(unsigned char) * 512);
cudaMalloc(&worker1_d, 256
sizeof(unsigned char));
for(i=0;i<512;i++){
worker1[i] = vec[i];
-------------------------Error Message for cudaMemcpy------------------------------------>
Multiple markers at this line
- Syntax error
- expected a “)”
- this declaration has no storage class or type specifier
- declaration is incompatible with “cudaError_t cudaMemcpy(void *, const void *,
size_t, cudaMemcpyKind)”
- a value of type “unsigned char **” cannot be used to initialize an entity of type “int”
cudaMemcpy(&worker1_d, worker1, 512*sizeof(unsigned char), cudaMemcpyHostToDevice);
Hi I have an unsigned char array that is added to worker1 using the simple for loop above, I then want to copy worker1 to worker1_d for cuda processing but the cudaMemcpy is causing an error, I have re-wrote it many times but cant get the syntax right.
any idea’s appreciated.
mark
