Hi, I ran a Linux program to increase the memory from 4 to 8 GB to a Jetson Nano Developer Kit. Afterwards, I tried to connect an external SSD for additional SWAP space. However, I’m getting the following error message. Was wondering if anyone may know what it means. Error Message
Moving to Jetson Nano forum for resolution.
Suppose you are using GPU enabled Keras.
Please noted that GPU could not use swap memory.
If you try to use it as a standard memory, it leads to some issues when GPU is accessing.
Thank you for your reply.
