HI all,
When I try to compile code I got such error:
Error1 error MSB3721: The command “-Xcompiler /wd4251,/wd4503 “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\bin\nvcc.exe” -dlink -o C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\smat_cuda.device-link.obj -Xcompiler “/EHsc /W3 /nologo /O2 /Zi /MD " -L"C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\bin\” -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\lib\x64” -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\lib\x64" base.lib smat.lib cudart.lib cublas.lib curand.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib -gencode=arch=compute_30,code=sm_30 --machine 64 “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\arange.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\diff.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\dot.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\copy.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\dropout.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\elemwise3.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\mask.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\rand.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\elemwise2.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\repeat.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\tile.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\transpose.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\reduce.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\reduce_x.cu.obj” “C:\Data\nbt3300-code\code\libs\smat\vcproj..\build\Release\obj\smat_cuda\reduce_y.cu.obj”" exited with code 1. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 7.5.targets 690 9 smat_cuda
Error 2 error LNK1181: cannot open input file ‘smat_cuda.lib’ C:\Data\nbt3300-code\code\libs\smat\vcproj\LINK smat_ext_demo
Error 3 error C2660: ‘cudnnSetPooling2dDescriptor’ : function does not take 8 arguments C:\Data\nbt3300-code\code\libs\smat\src\smat_cudnn\cudnn.cpp 759 1 smat_cudnn
Error 4 error C2065: ‘CUDNN_ADD_SAME_C’ : undeclared identifier C:\Data\nbt3300-code\code\libs\smat\src\smat_cudnn\cudnn.cpp 717 1 smat_cudnn
Any advise would be appreciated. Thanks in advance.
