I want to use the tao-converter file (on the jetson nx) to convert the unet model .etlt to int8 engine but get the error:
[INFO] Detected input dimensions from the model: (-1, 1, 320, 320)
[INFO] Model has dynamic shape. Setting up optimization profiles.
[INFO] Using optimization profile min shape: (1, 1, 320, 320) for input: input_1:0
[INFO] Using optimization profile opt shape: (4, 1, 320, 320) for input: input_1:0
[INFO] Using optimization profile max shape: (16, 1, 320, 320) for input: input_1:0
[ERROR] Network has dynamic or shape inputs, but no optimization profile has been defined.
[ERROR] Network validation failed.
[ERROR] Unable to create engine
this is my code:
./tao-converter -k nvidia_tlt
-c isbi_cal.bin
-e result.engine
-t int8
-p input_1:0,1x1x320x320,4x1x320x320,16x1x320x320
model_isbi_retrained.etlt
this is my dir:
export labels.txt nvinfer_config.txt tao-converter
isbi_cal.bin model_isbi_retrained.etlt setupmodel.sh
isbi_cal_data_file.txt model_isbi_retrained.tlt status.json
if i change the -p input_1:0 to -p input_1 i will get the error:
[WARNING] Tensor DataType is determined at build time for tensors not marked as input or output.
[ERROR] Wrong input name specified in -p, please double check.
Aborted (core dumped)
and if i change -p input_1, 1x1x320x320, 4x1x320x320, 16x1x320x320 to -p input_1, 1x3x320x320, 4x3x320x320, 16x3x320x320, also get error:
i also changed -p input_1:0,1x1x320x320,4x1x320x320,16x1x320x320
to -p input_1:0,1x3x320x320,4x3x320x320,16x3x320x320 \
get the same error:
[INFO] Using optimization profile min shape: (1, 3, 320, 320) for input: input_1:0
[INFO] Using optimization profile opt shape: (4, 3, 320, 320) for input: input_1:0
[INFO] Using optimization profile max shape: (16, 3, 320, 320) for input: input_1:0
Sorry for late reply.
Please change the key to tlt_encode
