error:no kernel image is available for execution in CUDA 10.0
I am using Jetson TX2 flashed with JetPack 4.2. When I try to use pcl gpu module with ROS, after successful compiling I get the following error in runtime:
Error: no kernel image is available for execution on the device /home/nvidia/Downloads/pcl-pcl-1.9.0/gpu/features/src/normal_3d.cu:250
terminate called after throwing an instance of ‘boost::exception_detail::clone_impl<boost::exception_detail::error_info_injectorboost::lock_error >’
what(): boost: mutex lock failed in pthread_mutex_lock: Invalid argument
[mapping/MappingMgr-1] process has died [pid 26645, exit code -6, cmd /opt/ros/melodic/lib/nodelet/nodelet manager __name:=MappingMgr __log:=/home/nvidia/.ros/log/35c8594c-af7b-11e9-9c4a-5e57f7762999/mapping-MappingMgr-1.log].
log file: /home/nvidia/.ros/log/35c8594c-af7b-11e9-9c4a-5e57f7762999/mapping-MappingMgr-1*.log
I am using the flag of sm_53 to compile the code. Additionally, the line giving the error in normal_3d.cu is cudaSafeCall( cudaGetLastError() ). Any help and suggestion would be appreciated.
Jetson TX2 is cc6.2 device you should be using sm_62
Thank you for your quick reply! and I am very grateful since it worked! quick question just for curiosity, when I typed nvcc -h, sm_53 was also one of the compatible capacity flags why didnt it work though?
It’s a lengthy subject. It is covered in many questions elsewhere.
Here is one answer, and also refer to the other answers linked from that answer.
[url]cuda - NVCC -arch -code - Stack Overflow
It is also covered in the nvcc documentation.
[url]NVCC :: CUDA Toolkit Documentation
Many thanks for your answer!
