I’m encountering an error when running the vss-engine:2.3.0 container. The error is:
No such model 'openai-compat'
Here’s my setup:
.env configuration:
VIA_IMAGE=nvcr.io/nvidia/blueprint/vss-engine:2.3.0
VLM_MODEL_TO_USE=openai-compat
Request sent via cURL:
curl -X POST http://localhost:8100/summarize \
-H "Content-Type: application/json" \
-d '{
"model": "openai-compat",
From the logs and API response, it seems like openai-compat is not recognized as a valid model.
It’s a valid model type, you can refer to our source code vlm_pipeline.py.
Could you please elaborate on your requirements and the operation steps?
It has to use the name gpt-4o to be correct.
.env configuration:
VIA_VLM_OPENAI_MODEL_DEPLOYMENT_NAME=gpt-4o
-d '{
"model": "gpt-4o",
"api_type": "openai",
system
Closed
6
