when i try to install pycuda this error shows up
sudo sh ./install_pycuda.sh
ERROR: nvcc not found
How can i fix that?
How can i fix that?
Hi @gurselturkeri, can you confirm that you have CUDA Toolkit installed?
/usr/local/cuda/bin/nvcc --version
If you are able to run that, you may want to add this to your ~/.bashrc
to have CUDA in your environment’s PATH:
export PATH=/usr/local/cuda/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda/lib64\
${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
my version:
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Feb_28_22:34:44_PST_2021
Cuda compilation tools, release 10.2, V10.2.300
Build cuda_10.2_r440.TC440_70.29663091_0
in bashrc already has
export PATH=/usr/local/cuda-10.2/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64:$LD_LIBRARY_PATH
I’m solving with these:
I add cuda path in where pycuda install file by using terminal.
then sudo sh ./install_pycuda.sh
is work
