I am getting the below error when i try to integrate the yolo_v3 trt engine with deepstream.
root@4892b1252985:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app-trtis# deepstream-app -c source1_video_boxnet_gpu.txt
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: INVALID_ARGUMENT: getPluginCreator could not find plugin BatchTilePlugin_TRT version 1
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: safeDeserializationUtils.cpp (293) - Serialization Error in load: 0 (Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: INVALID_STATE: std::exception
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: INVALID_CONFIG: Deserialize the cuda engine failed.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1567 Deserialize engine failed from file: /opt/nvidia/deepstream/deepstream-5.0/samples/trtis_model_repo/box_yolo_models/trt.engine
0:00:00.424599605 81 0x5598242f7ac0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/trtis_model_repo/box_yolo_models/trt.engine failed
0:00:00.424622334 81 0x5598242f7ac0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/trtis_model_repo/box_yolo_models/trt.engine failed, try rebuild
0:00:00.424629889 81 0x5598242f7ac0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:934 failed to build network since there is no model file matched.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:872 failed to build network.
0:00:00.424775432 81 0x5598242f7ac0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
0:00:00.424786956 81 0x5598242f7ac0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed
0:00:00.424793188 81 0x5598242f7ac0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings
0:00:00.424899136 81 0x5598242f7ac0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:00.424905144 81 0x5598242f7ac0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app-trtis/config_infer_primary_yolov3.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
Here I am attaching my config files.
source1_video_boxnet_gpu.txt (2.2 KB) config_infer_primary_yolov3.txt (2.5 KB)
