ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: UffParser: Validator error: FirstDimTile_4:
im using docker container nvcr.io/nvidia/deepstream:5.1-21.02-base
config file , i have placed the model and label files in the corresponding path below .
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=0
labelfile-path=/opt/nvidia/deepstream/deepstream-5.1/src/Deepstream-PoC/models/Primary_Bottle_SSD/ssd_labels.txt
model-engine-file=/opt/nvidia/deepstream/deepstream-5.1/src/Deepstream-PoC/models/Primary_Bottle_SSD/ssd_resnet18_retrained_epoch_040_bo_99_bl_94_rej_84.etlt_b1_gpu0_fp32.engine
tlt-encoded-model=/opt/nvidia/deepstream/deepstream-5.1/src/Deepstream-PoC/models/Primary_Bottle_SSD/ssd_resnet18_retrained_epoch_040_bo_99_bl_94_rej_84.etlt
tlt-model-key=nvidia_tlt
infer-dims=3;300;300
uff-input-order=0
maintain-aspect-ratio=1
uff-input-blob-name=Input
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=4
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
output-blob-names=NMS
parse-bbox-func-name=NvDsInferParseCustomNMSTLT
custom-lib-path=/home/ubuntu/PoC/customLib/libnvds_infercustomparser_tlt.so
classifier-async-mode=0
[class-attrs-all]
pre-cluster-threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=3
codec=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
display-text=1
below is the error
0:00:00.227926915 11029 0x55d94f955200 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: UffParser: Validator error: FirstDimTile_4: Unsupported operation _BatchTilePlugin_TRT
parseModel: Failed to parse UFF model
ERROR: tlt/tlt_decode.cpp:274 failed to build network since parsing model errors.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:797 Failed to create network using custom network creation function
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:862 Failed to get cuda engine from custom library API
0:00:00.805065781 11029 0x55d94f955200 ERROR                nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1736> [UID = 1]: build engine file failed
• DeepStream Version
• TensorRT Version
Hi h9945394143,
im trying to generate an Model engine file ,with below “tlt-encoded-model”
gpu-id=0
labelfile-path=../../model/labels.txt
#model-engine-file=../../../../../../../../home/ubuntu/PoC/model/Primary_Bottle_SSD/ssd_resnet18_retrained_epoch_040_bo_99_bl_94_rej_84.etlt_b1_gpu0_fp32.engine
tlt-encoded-model=../../model/yolov4_resnet18_epoch_050.etlt
#int8-calib-file=../../../../../../../../home/ubuntu/PoC/models/ssd/cal.bin
uff-input-order=0
batch-size=1
network-mode=0
num-detected-classes=2
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
custom-lib-path=../../customLib/libnvds_infercustomparser_tlt.so
[class-attrs-all]
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Seems “Unsupported operation _BatchTilePlugin_TRT” error from below error log. Can you try latest TRT plugins in: deepstream_tao_apps/TRT-OSS/x86 at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: UffParser: Validator error: FirstDimTile_4: Unsupported operation _BatchTilePlugin_TRT
