Error nvidia docker daemon (wls2)
I have installed cuda (12.2) and cudnn(8.9.4) on WSL2. The tests work fine.
I want to virtualize an application with docker (Docker version 24.0.5, build 24.0.5-0ubuntu1~22.04.1) which requires the use of the gpu. Docker is connected to WSL2. I have previously installed NVIDIA CONTAINER TOOLKIT (1.14.1) and nvidia-container-runtime (3.14.0-1) and restart docker.
I get this response after the docker-compose command: Error response from daemon: unknown or invalid runtime name: nvidia.
I get the same response with this command: sudo docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi
How to fix it ?
Thanks for your help
