ERROR: Nvidia driver is not loaded Ubuntu 20.04 HP Zbook Studio G8(RTX3080 Ti)
Hello
I’m not able to install driver on my laptop. Tried different versions(470, 510, 515)
user@CND1451MDK:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
````Preformatted text`
Here is my debug info
[nvidia-bug-report.log.gz|attachment](upload://ppuuc6ElhvF00uTNAjda41P94Bp.gz) (673.8 KB)
Please attach the log file again. Please use the upload button, horizontal line with upward arrow in the line of formatting options when writing a post.
Here it is
nvidia-bug-report.log.gz (673.8 KB)
On hp zbook, you’need to use kernel 5.15.
https://forums.developer.nvidia.com/t/nvidia-smi-error-with-ubuntu-20-04-on-laptop/220246/4?u=generix
Tried 5.10, the same issue.
nvidia-bug-report.log.gz (2.1 MB)
Unfortunately, there no easy way to use 5.15 on Ubuntu 20.04, so I’m not able to try it
The nvidia driver is actually working, it’s just not loading on boot and nvidiafb (not part of nvidia driver) is not blacklisted. I suspect you broke the nvidia driver install when desperately trying to make it work previously. Please uninstall the runfile driver by running it again with --uninstall option, remove all nvidia packages, then install the nvidia driver again using Software&Updates.
You can use the kernel-proposed ppa to fetch the 5.15 kernel
https://www.linuxcapable.com/how-to-install-linux-kernel-5-15-on-ubuntu-20-04/
