Hello, When I try to open nvidia-settings after I set prime-select to intel. nvidia-settings is blank and I get this in my terminal.
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:5445): GLib-GObject-CRITICAL **: 09:37:14.262: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 09:37:14.266: PRIME: No offloading required. Abort
** Message: 09:37:14.266: PRIME: is it supported? no
I have nvidia-driver-495 installed on Zorin 16.
nvidia-settings opens fine when prime-select is set to nvidia.
Before I updated Nvidia packages, Nvidia settings would normally open on prime-select on intel. There were not a lot of options, but it would allow me to reenable the GPU.
