Error Nvinferaudio on DeepStream 6.1
• Hardware Platform (Jetson / GPU) : Jetson and dGPU
• DeepStream Version : 6.1
• JetPack Version (valid for Jetson only) : 5.0.2
• TensorRT Version : 8.4.1
• NVIDIA GPU Driver Version (valid for GPU only) : 515.65.01
• Issue Type( questions, new requirements, bugs) : bugs
When I create 「Sample Audio pipeline graph」 pipeline on DeepStream 6.1, I get this error.
Just I change alsasink to fakesink, and add nvinferaudio between nvstreammux and nvstreamdemux.
However I don’t get this error to use DeepStream 6.0.
I run this command in the docker container.
Is there any solution to this?
command line
USE_NEW_NVSTREAMMUX=yes gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sonyc_mixed_audio.wav name=source_0 ! queue ! audioconvert ! audioresample ! mux.sink_0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sonyc_mixed_audio.wav name=source_1 ! queue ! audioconvert ! audioresample ! mux.sink_1 nvstreammux name=mux batch-size=2 ! nvinferaudio config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-audio/configs/ds_audio_sonyc_test_config.txt model-engine-file="/engine.engine" batch-size=2 audio-transform="melsdb,fft_length=2560,hop_size=692,dsp_window=hann,num_mels=128,sample_rate=44100,p2db_ref=(float)1.0,p2db_min_power=(float)0.0,p2db_top_db=(float)80.0" config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-audio/configs/config_infer_audio_sonyc.txt audio-framesize=441000 audio-hopsize=110250 ! nvstreamdemux name=demux demux.src_0 ! audioconvert ! audioresample ! fakesink async=false demux.src_1 ! audioconvert ! audioresample ! fakesink async=false
DeepStream 6.0 output (Jetson)
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
Could not find group property
** ERROR: <gst_nvinfer_parse_config_file:652>: failed
Setting pipeline to PAUSED ...
ERROR: Deserialize engine failed because file path: /engine.engine open error
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
INFO: [FullDims Engine Info]: layers num: 2
0   INPUT  kFLOAT input.1         1x635x128       min: 1x1x635x128     opt: 2x1x635x128     Max: 2x1x635x128
1   OUTPUT kFLOAT output1         31              min: 0               opt: 0               Max: 0
Pipeline is PREROLLING ...
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.517: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.534: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.550: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.566: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.581: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.597: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.612: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.629: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.644: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.660: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.677: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.694: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.710: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.726: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.745: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.761: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.776: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.792: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.807: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.822: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.837: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.853: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.868: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.883: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.898: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.913: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.928: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.943: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.959: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.974: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:08.990: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.005: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.020: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.035: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.050: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.065: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.081: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.095: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.110: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.125: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.140: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.154: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.169: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.184: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.198: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-launch-1.0:32): GStreamer-WARNING **: 04:53:09.213: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:12.777220416
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
DeepStream 6.1 output (Jetson)
Failed to load config file: No such file or directory
WARNING: Deserialize engine failed because file path: /engine.engine open error
WARNING: [TRT]: onnx2trt_utils.cpp:367: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
ERROR: from element /GstPipeline:pipeline0/GstNvInferAudio:nvinferaudio0: Internal data stream error.
Additional debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-utils/gst-nvdsinferbase/gstnvinferbase.cpp(1012): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInferAudio:nvinferaudio0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.005104896
App sequence error release pad called before push events
100ms timeout exhausted. App sequence error release pad called before push events
Current nvstreamdemux does not support audio batch.
