Error occurred during installation of Adobe Substance 3D Painter: Command failed: “C:\Users\xxx\AppData\Local\ov\pkg\substance3dpainter-connector-102.1.72\Substance3DPainterOmniSetup.exe” /INSTALL
δ���������쳣: System.IO.FileNotFoundException: δ���ҵ��ļ���C:\Users\xxx\Documents\Adobe\Adobe Substance 3D Painter\plugins\Omniverse-Connector����
�� System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
�� System.IO.Directory.InternalCreateDirectory(String fullPath, String path, Object dirSecurityObj, Boolean checkHost)
�� System.IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
�� System.IO.Directory.CreateDirectory(String path)
�� Substance3DPainterOmniSetup.Connector.DirectoryCopy(String sourceDirName, String destDirName, Boolean copySubDirs)
�� Substance3DPainterOmniSetup.Connector.CopyFilesToPluginFolder()
�� Substance3DPainterOmniSetup.Connector.InstallConnector(Boolean Auto)
�� Substance3DPainterOmniSetup.Program.Main(String args)
