Error occurred during installation of Nucleus Workstation
Ubuntu 18.04
How can I solve this problem?
Error occurred during installation of Nucleus Workstation: Command failed: “/home/isaac/.local/share/ov/pkg/nucleus-workstation-2021.3.2/setup/nucleus-setup” -i
Unhandled exception. System.AggregateException: Not all processes in process tree could be terminated. (Operation not permitted)
—> System.ComponentModel.Win32Exception (1): Operation not permitted
— End of inner exception stack trace —
at System.Diagnostics.Process.Kill(Boolean entireProcessTree)
at OmniProcesses.Processes.StopProcess(String ProcessName)
at NucleusSetup.Program.UpdateComponentToml(String ComponentConfigDir)
at NucleusSetup.Program.UpdateComponentTomls()
at NucleusSetup.Program.Install()
at NucleusSetup.Program.Main(String args)
Aborted
Moving this to the Omniverse Nucleus category with Nucleus experts.
Does a reinstall work? You could try doing the cleanup, reboot then a reinstall.
See: Cleanup-Tool — Omniverse Launcher documentation
Hi @yushi.jack! I contacted the Nucleus development team about your problem. I will post back when I have more information!
Thank you for your comment.
I have tried the cleanup tool several times, but I get the above error.
Please let us know if you have the latest Launcher version. To check the version, click the “user” icon at the top right of the Launcher and select “About”. It should be version 1.5.1.
If not, there should be a notification at the “Bell” icon next to the “user” icon for an update. To update, exit the Launcher using the “exit” button in the “user” icon menu. Then run the Omniverse Launcher using the Appimage file.
Hi
have you fix the problem, cause I’ve met the same one
Please make sure you’re installing nucleus into user directory that are ANSI characters only.
