Hello, we are using the T5000 on a custom-designed carrier board (not official dev kit). We are using Windows+NVIDIA SDK Manager,+WSL to flash JetPack and the system image, but an error occurs during the flashing process to the Jetson Linux flash memory. 22:14:47 ERROR: Flash Jetson Linux - flash: — Parsing baseboard ID (ERROR: calculated CRC8 0x35 != stored CRC8 0xff) succeeded.
22:14:47 ERROR: Flash Jetson Linux - flash: Error: Target board not found.
22:14:47 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
The details are as follows:
Thank you for your reply. How exactly should I modify my BOARDID? Where can I find these specific parameters? I noticed some information in the guide, but I’m not sure if it’s relevant.
Hello, here is the log from running sudo ./l4t_initrd_flash.sh --erase-all jetson-agx-thor-devkit internal.
I have also noticed that other developers in the community have encountered similar issues.
Thank you for your reply. I used your commands to flash the device, but encountered a different error. However, I think it might have had some effect; normally, the fan doesn’t spin in recovery mode, but after using your commands—even though an error occurred—the fan did start spinning.
Hello, I tried installing the Ubuntu system today and then installed the NVIDIA SDK manager on Ubuntu using the script you provided. The installation was successful. Previously, it was installed under Windows using WSLs and SDK managers. I am not sure if there is a difference between these two methods, which means that it is necessary to burn successfully in Ubuntu environment. I will now use SDK manager for firmware burning on Ubuntu.
I saw official information that after Jetpack 7.0, it is possible to directly use SDK Manager for burning on Windows. I would like to know if there are any differences between the two methods of burning on Windows and Ubuntu?
I will try using SDK manager for firmware flashing next, and if there are no issues, I will close the issue. Thank you very much for your technical support and response!
Hello, I just used NVIDIA SDK manager to flash firmware and still encountered the same error. It is possible to flash using scripts and USB+ISO format. May I ask what the problem is? Is there anything else that needs to be modified?
Sorry, I didn’t understand what you meant. My current problem is that both script burning firmware and USB+ISO can successfully flash, but only when flashing with SDK Mannager will there be a failure. Do you mean I need to create a dedicated conf file for our current carrier board?
