Error of VPI on x86
I wanna do the algorithm on jetson finaly,but evaluate it on x86 first.
Run the code(tutorial_blur) on x86 ,got an error,without message ,I tracked each line,
the core occur in this is
vpiSubmitBoxFilter(stream, backendType, image, blurred, 5, 5, VPI_BOUNDARY_COND_ZERO);
what is wrong?
What kind of error do yo meet? Segmentation fault?
We do have a box filter sample located at /opt/nvidia/vpi/samples/tutorial_blur/.
Could you try if the sample can work correctly or not on your environment first?
Thanks,
I’m using this sample,I cannot get any error message,so I put some std::cout to trace each line。
main.cpp (7.7 KB)
what version of CUDA toolkit and gpu driver require by VPI ?
and got error while running convolution 2d sample:
VPI_ERROR_INTERNAL: (cudaStreamCreate:cudaErrorInsufficientDriver)
The error indicates the the CUDA version is incompatible.
Please noted that VPI requires a CUDA 10.2 environment.
