[Error] [omni.isaac.core_nodes] CUDA error 801: cudaErrorNotSupported - operation not supported)
Hello, I’m trying to use isaac sim with visual slam solution.
I just installed isaac sim and test sample scene with visual slam package. But I couldn’t get correct image publish from simulated robots after loading sample scene and start playing. The image topic just contains black image. And other topics were published correctly. I tried running isaac sim on docker container, then I can see correct image publish from rviz. But, I couldn’t use in docker container because the simulation becomes too slow and image publish rate becomes below 3hz. So, I think it’s not a hardware problem. And I can see the error message from isaac sim like below.
What’s the difference with docker container version and Is there fix for this problem.
My system configuration is as bellows.
OS : Ubuntu 22.04
GPU : 4 RTX 2080 Ti
Driver : 535.129.03
CUDA : 12.2
Hi @hyoungrock.kim - Can you please also confirm Isaac Sim version?
I’m using 2023.1.1 version
same error while using isaac-sim 2023.1.1 in docker container with ROS1 Camera Helper graph node
It might be caused by using multiple GPUs, as when I run Isaac Sim in a Docker container with only one GPU, the graph works normally. Additionally, if I pass extra arguments --/renderer/multiGpu/activeGpus='0,1,2,3' to the Isaac Sim app selector in Headless mode, it also works normally.
