Error on clara render start
Hello! on installing render server pod is not starting:
kubectl logs clara-render-server-clara-renderer-6699d57957-zhsq6 renderer-clara-renderer
[INFO ] 2020-04-27 13:08:11.604 For using OptiX, driver version 435.12 and Docker version 19.03 is required
[WARN ] 2020-04-27 13:08:11.606 Switching to non-OptiX renderer
[INFO ] 2020-04-27 13:08:11.607 Starting NvRTVolRenderServer
[INFO ] 2020-04-27 13:08:11.612 Creating gPRC service on 0.0.0.0:2050
[INFO ] 2020-04-27 13:08:11.676 Using NvEncode API 9.1
[INFO ] 2020-04-27 13:08:11.679 Video encoder max resolution 4096x4096
[INFO ] 2020-04-27 13:08:11.751 Using cache directory '/root/.cache/nvrtvolrenderer'
[INFO ] 2020-04-27 13:08:11.808 === All CUDA Devices ======================
[INFO ] 2020-04-27 13:08:11.808 CUDA Device 0: Tesla K80       [Arch 3.7]
[INFO ] 2020-04-27 13:08:11.808 === Configured CUDA Devices ===============
[ERROR] 2020-04-27 13:08:11.893 (/RenderServer/build/renderserver/src/RenderServer-build/nvrtvolrenderer/nvrtvol/src/NvRTVol/nvrtvol/src/nvrtvol/core/cudatools/CudaProgram.cpp: 158) Encountered CUDA driver error 218 in file /RenderServer/build/renderserver/src/RenderServer-build/nvrtvolrenderer/nvrtvol/src/NvRTVol/nvrtvol/src/nvrtvol/core/cudatools/CudaProgram.cpp line 158 : a PTX JIT compilation failed
[ERROR] 2020-04-27 13:08:11.893 Failed to compile code
[ERROR] 2020-04-27 13:08:11.893 Compile error log:
[ERROR] 2020-04-27 13:08:11.893 ptxas fatal   : SM version specified by .target is higher than default SM version assumed
[ERROR] 2020-04-27 13:08:11.893 Compile info log:
[ERROR] 2020-04-27 13:08:11.922 Error:
It’s because of too old gpu. Can I skip render server installation to use pipelines? Thanks
