Error on installing TensorRT with SDK Manager 1.3.1
Please provide the following info:
Hardware Platform: DRIVE AGX Xavier Developer Kit
Software Version: DRIVE Software 10
Host Machine Version: native Ubuntu 18.04
SDK Manager Version: 1.3.1.7110
Hi, I updated my SDK Manager today and wanted to reflash the Drive AGX Pegasus System. I get an error when it tries to install TensorRT on the host system.
I have tried to uninstall and redownload everything but no success. Any Idea on how to resolve this?
Here is relevant part of the log:
14:49:37 INFO: TensorRT (with cuDNN 7.5) x86: exec_command: sudo apt-get update; sleep 0.5; sudo apt-get -y --allow-downgrades install libcudnn7=7.5* libcudnn7-dev=7.5* graphsurgeon-tf=5.1* uff-converter-tf=5.1* libnvinfer5=5.1* libnvinfer-dev=5.1* libnvinfer-samples=5.1* python3-libnvinfer=5.1* python3-libnvinfer-dev=5.1* python-libnvinfer=5.1* python-libnvinfer-dev=5.1* tensorrt=5.1* libgie-dev=5.1*
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: Some packages could not be installed. This may mean that you have
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: requested an impossible situation or if you are using the unstable
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: distribution that some required packages have not yet been created
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: or been moved out of Incoming.
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: The following information may help to resolve the situation:
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: The following packages have unmet dependencies:
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: libnvinfer-dev : Breaks: libgie-dev (< 5.1.5-1+cuda10.1) but 5.1.4-1+cuda10.2 is to be installed
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: tensorrt : Depends: libnvinfer5 (= 5.1.4-1+cuda10.2) but 5.1.5-1+cuda10.1 is to be installed
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: Depends: libnvinfer-dev (= 5.1.4-1+cuda10.2) but 5.1.5-1+cuda10.1 is to be installed
14:11:06 ERROR: TensorRT (with cuDNN 7.5) x86: E: Unable to correct problems, you have held broken packages.
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: [ Package Install Finished with Error ]
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: [host] [ 117.50 MB used. Disk Avail: 143.42 GB ]
14:11:06 INFO: TensorRT (with cuDNN 7.5) x86: [ NV_TENSORRT_HOST_COMP Install took 22s ]
14:11:06 ERROR: TensorRT (with cuDNN 7.5) x86: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y --allow-downgrades install libcudnn7=7.5* libcudnn7-dev=7.5* graphsurgeon-tf=5.1* uff-converter-tf=5.1* libnvinfer5=5.1* libnvinfer-dev=5.1* libnvinfer-samples=5.1* python3-libnvinfer=5.1* python3-libnvinfer-dev=5.1* python-libnvinfer=5.1* python-libnvinfer-dev=5.1* tensorrt=5.1* libgie-dev=5.1* ; [error]: exit status 100; [deb_path]: /home/fabian/Downloads/nvidia/sdkm_downloads/nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506_1-1_amd64.deb
14:11:06 ERROR: TensorRT (with cuDNN 7.5) x86: command terminated with error
14:11:06 SUMMARY: TensorRT (with cuDNN 7.5) x86: APT system is broken and requires manual fix
Hi @fabian.h,
Please share ~/.nvsdkm/logs/DRIVE_Software_10.0_Linux_OS/NV_TENSORRT_HOST_COMP.log for our investigation. At the same time, could you try to narrow down what’s the problem in below command by running it manually?
Hi @VickNV,
there seems to be an dependency issue. I get the same error as in the logs when running it manually, but there is some more info:
Building dependency tree
Reading state information
 Done
Selected version ‘7.5.1.14-1+cuda10.2’ (NVIDIA CUDA:localhost [amd64]) for ‘libcudnn7’
Selected version ‘7.5.1.14-1+cuda10.2’ (NVIDIA CUDA:localhost [amd64]) for ‘libcudnn7-dev’
Selected version ‘5.1.4-1+cuda10.2’ (NVIDIA CUDA:localhost [amd64]) for ‘graphsurgeon-tf’
Selected version ‘5.1.4-1+cuda10.2’ (NVIDIA CUDA:localhost [amd64]) for ‘uff-converter-tf’
Selected version ‘5.1.5-1+cuda10.1’ (NVIDIA CUDA:developer.download.nvidia.com [amd64]) for ‘libnvinfer5’
Selected version ‘5.1.5-1+cuda10.1’ (NVIDIA CUDA:developer.download.nvidia.com [amd64]) for ‘libnvinfer-dev’
Selected version ‘5.1.4-1+cuda10.2’ (NVIDIA CUDA:localhost [all]) for ‘libnvinfer-samples’
Selected version ‘5.1.5-1+cuda10.1’ (NVIDIA CUDA:developer.download.nvidia.com [amd64]) for ‘python3-libnvinfer’
Selected version ‘5.1.5-1+cuda10.1’ (NVIDIA CUDA:developer.download.nvidia.com [amd64]) for ‘python3-libnvinfer-dev’
Selected version ‘5.1.5-1+cuda10.1’ (NVIDIA CUDA:developer.download.nvidia.com [amd64]) for ‘python-libnvinfer’
Selected version ‘5.1.5-1+cuda10.1’ (NVIDIA CUDA:developer.download.nvidia.com [amd64]) for ‘python-libnvinfer-dev’
Selected version ‘5.1.4.2-1+cuda10.2’ (NVIDIA CUDA:localhost [amd64]) for ‘tensorrt’
Selected version ‘5.1.4-1+cuda10.2’ (NVIDIA CUDA:localhost [all]) for ‘libgie-dev’
Seems like there is a problem with the selected cuda-versions. My version is 10.2
/usr/local/cuda/bin/nvcc --version
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_19:24:38_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
fabian@LB-FABIANH:~$ cat /usr/local/cuda/version.txt
CUDA Version 10.2.89
Running apt clean and apt auto-clean did not help.
Here is the complete log:
Info: [host] [ Disk Avail:124.35 GB ]
Info: NV_TENSORRT_HOST_COMP include 1 package
Info: [ Package Install Started ]
Info: deb installer start to install
Info: exec_command: dpkg -f /home/fabian/Downloads/nvidia/sdkm_downloads/nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506_1-1_amd64.deb Package | tr -d ‘\n’
Info: exec_command: dpkg -f /home/fabian/Downloads/nvidia/sdkm_downloads/nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506_1-1_amd64.deb Version | tr -d ‘\n’
Info: exec_command: sudo -E apt-get install -y --allow-downgrades ‘/home/fabian/Downloads/nvidia/sdkm_downloads/nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506_1-1_amd64.deb’
Reading package lists
nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506 is already the newest version (1-1).
0 upgraded, 0 newly installed, 0 to remove and 248 not upgraded.
Info: exec_command: dpkg -L nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506 | grep ‘.pub$’ | tr -d ‘\n’
Info: exec_command: sudo apt-key add /var/nv-tensorrt-repo-cuda10.2-trt5.1.4.2-ga-20190506/7fa2af80.pub
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Info: exec_command: sudo apt-get check
Info: exec_command: sudo apt-get update; sleep 0.5; sudo apt-get -y --allow-downgrades install libcudnn7=7.5* libcudnn7-dev=7.5* graphsurgeon-tf=5.1* uff-converter-tf=5.1* libnvinfer5=5.1* libnvinfer-dev=5.1* libnvinfer-samples=5.1* python3-libnvinfer=5.1* python3-libnvinfer-dev=5.1* python-libnvinfer=5.1* python-libnvinfer-dev=5.1* tensorrt=5.1* libgie-dev=5.1*
Get:1 file:/var/cuda-repo-10-2-local-10.2.19-430.17 InRelease
Ign:1 file:/var/cuda-repo-10-2-local-10.2.19-430.17 InRelease
Get:2 file:/var/cuda-repo-10-2-local-10.2.19-cross-aarch64 InRelease
Ign:2 file:/var/cuda-repo-10-2-local-10.2.19-cross-aarch64 InRelease
Get:3 file:/var/nv-tensorrt-repo-cuda10.2-trt5.1.4.2-ga-20190506 InRelease
Ign:3 file:/var/nv-tensorrt-repo-cuda10.2-trt5.1.4.2-ga-20190506 InRelease
Get:4 file:/var/cuda-repo-10-2-local-10.2.19-430.17 Release [574 B]
Get:5 file:/var/cuda-repo-10-2-local-10.2.19-cross-aarch64 Release [574 B]
Get:6 file:/var/nv-tensorrt-repo-cuda10.2-trt5.1.4.2-ga-20190506 Release [574 B]
Hit:7 Index of /graphics-drivers/ppa/ubuntu bionic InRelease
Hit:8 Index of /ubuntu bionic InRelease
Hit:9 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:10 Index of /ubuntu bionic-updates InRelease
Hit:11 Index of linux/ubuntu/ bionic InRelease
Hit:12 Index of /ubuntu bionic-backports InRelease
Hit:13 Index of /repos/ms-teams/ stable InRelease
Ign:15 Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease
Hit:16 Index of /ubuntu bionic-security InRelease
Ign:18 Index of /compute/machine-learning/repos/ubuntu1804/x86_64 InRelease
Hit:19 Index of /compute/cuda/repos/ubuntu1804/x86_64 Release
Hit:20 Index of /compute/machine-learning/repos/ubuntu1804/x86_64 Release
Info: [ Package Install Finished with Error ]
Info: [host] [ 72.00 KB used. Disk Avail: 124.35 GB ]
Info: [ NV_TENSORRT_HOST_COMP Install took 14s ]
Error: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y --allow-downgrades install libcudnn7=7.5* libcudnn7-dev=7.5* graphsurgeon-tf=5.1* uff-converter-tf=5.1* libnvinfer5=5.1* libnvinfer-dev=5.1* libnvinfer-samples=5.1* python3-libnvinfer=5.1* python3-libnvinfer-dev=5.1* python-libnvinfer=5.1* python-libnvinfer-dev=5.1* tensorrt=5.1* libgie-dev=5.1* ; [error]: exit status 100; [deb_path]: /home/fabian/Downloads/nvidia/sdkm_downloads/nv-tensorrt-repo-ubuntu1804-cuda10.2-trt5.1.4.2-ga-20190506_1-1_amd64.deb
a URI in a source.list file including 5.1.5 packages may cause the problem.
Please back up all /etc/apt/sources.list.d/* files, remove them and then try again.
Hi @VickNV
these where the files I removed (also the list.save files):
ls ~/sources_backup/*.list
/home/fabian/sources_backup/cuda-10-2-local-10.2.19-430.17.list
/home/fabian/sources_backup/cuda-10-2-local-10.2.19-cross-aarch64.list
/home/fabian/sources_backup/cuda.list
/home/fabian/sources_backup/google-chrome.list
/home/fabian/sources_backup/graphics-drivers-ubuntu-ppa-bionic.list
/home/fabian/sources_backup/nvidia-machine-learning.list
/home/fabian/sources_backup/nv-tensorrt-cuda10.2-trt5.1.4.2-ga-20190506.list
/home/fabian/sources_backup/teams.list
now it can’t find the packages:
Hit:1 Index of linux/ubuntu/ bionic InRelease
Hit:2 Index of /ubuntu bionic InRelease
Hit:3 Index of /ubuntu bionic-updates InRelease
Hit:4 Index of /ubuntu bionic-backports InRelease
Hit:5 Index of /ubuntu bionic-security InRelease
E: Version ‘7.5*’ for ‘libcudnn7’ was not found
E: Version ‘7.5*’ for ‘libcudnn7-dev’ was not found
E: Unable to locate package graphsurgeon-tf
E: Unable to locate package uff-converter-tf
E: Unable to locate package libnvinfer5
E: Unable to locate package libnvinfer-dev
E: Unable to locate package libnvinfer-samples
E: Unable to locate package python3-libnvinfer
E: Unable to locate package python3-libnvinfer-dev
E: Unable to locate package python-libnvinfer
E: Unable to locate package python-libnvinfer-dev
E: Unable to locate package tensorrt
E: Unable to locate package libgie-dev
Info: [host] [ 24.00 KB used. Disk Avail: 81.40 GB ]
Info: [ NV_TENSORRT_HOST_COMP Install took 12s ]
I suspect the issue is from one of below lists (propably nvidia-machine-learning.list).
So please copy “only” below three source lists (should be from DRIVE Software 10 installation) to /etc/apt/sources.list.d directory and try again.
If it still doesn’t help, please try clean reinstallation by install after running below commands.
$ rm /etc/apt/sources.list.d/*
$ rm -rf ~/.nvsdkm* ~/Downloads/nvidia/sdkm_downloads* ~/nvidia/nvidia_sdk*
Thanks, that worked!
