I try to run below github project with JetsonNX and JetPack4.6.
But we found errors like below;
admin@usr-desktop:/workspaces/isaac_ros-dev$ colcon build && . install/setup.bash
Starting >>> isaac_ros_nvengine_interfaces
Starting >>> isaac_ros_test
Starting >>> isaac_ros_common
Finished <<< isaac_ros_test [2.81s]
Finished <<< isaac_ros_common [21.2s]
Finished <<< isaac_ros_nvengine_interfaces [28.0s]
Starting >>> isaac_ros_dnn_encoders
— stderr: isaac_ros_nvengine
/usr/bin/ld:/workspaces/isaac_ros-dev/src/isaac_ros_common/isaac_ros_nvengine/gxf/lib/gxf_jetpack46/core/libgxf_core.so: file format not recognized; treating as linker script
/usr/bin/ld:/workspaces/isaac_ros-dev/src/isaac_ros_common/isaac_ros_nvengine/gxf/lib/gxf_jetpack46/core/libgxf_core.so:1: syntax error
collect2: error: ld returned 1 exit status
make[2]: *** [libgxe_node.so] Error 1
make[1]: *** [CMakeFiles/gxe_node.dir/all] Error 2
make: *** [all] Error 2
Failed <<< isaac_ros_nvengine [15.5s, exited with code 2]
Aborted <<< isaac_ros_dnn_encoders [44.4s]
Summary: 3 packages finished [1min 13s]
1 package failed: isaac_ros_nvengine
1 package aborted: isaac_ros_dnn_encoders
1 package had stderr output: isaac_ros_nvengine
3 packages not processed
Question:
Are there anyone success to run this github project with JetsonNX?
We would appreciate if you tell us how to solve this issue.
Best regards,
