Hello!
I am recently getting the error:
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py/omni/ext/_impl/_internal.py", line 163, in _custom_importer
return _import_public(ext_module.path, ext_module.name, reload_enabled)
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py/carb/profiler/__init__.py", line 79, in wrapper
r = f(*args, **kwds)
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py/omni/ext/_impl/_internal.py", line 84, in _import_public
module = import_module(module_name)
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py/omni/ext/_impl/custom_importer.py", line 76, in import_module
return importlib.import_module(name)
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/__init__.py", line 26, in <module>
from ._impl.bundles import Bundle
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/bundles.py", line 111, in <module>
from .autonode.type_definitions import AutoNodeTypeConversion
File "/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/autonode/type_definitions.py", line 8, in <module>
Vector3d = NewType("Vector3d", np.ndarray)
AttributeError: module 'numpy' has no attribute 'ndarray'
2024-08-26 09:00:57 [1,473ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.graph.core' in '/home/christof/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph' failed to load.
Does anyone know how to fix it? In the commandline the call for numpy.ndarray is working.
It is not working in a conda environment neither starting it from omniverse launcher.
Best regards,
Christof
