Error on warp kernel
i have an OS level error while trying and running a little test program that uses the warp extension (activated in code). The program is this:
import warp as wp
import numpy as np
@wp.kernel
def add(a: wp.array(dtype=float)):
i=wp.tid()
a[i]+=1.0
return;
array=wp.array(1024, dtype=float, device=“cuda”)
wp.launch(kernel=add, dim=1024, inputs=[array], device=“cuda”)
and it yields this error:
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] [py stderr]: OSError: could not get source code
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] At:
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] /home/paolo/.local/share/ov/pkg/deps/691541202ea2678c05b45f92ff5d1d8c/python/lib/python3.7/inspect.py(786): findsource
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] /home/paolo/.local/share/ov/pkg/deps/691541202ea2678c05b45f92ff5d1d8c/python/lib/python3.7/inspect.py(955): getsourcelines
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] /home/paolo/.local/share/ov/pkg/deps/691541202ea2678c05b45f92ff5d1d8c/python/lib/python3.7/inspect.py(973): getsource
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] /home/paolo/.local/share/ov/pkg/deps/7c44b65c46ba8b7ef0a7f2f8232f2685/extscache/omni.warp-0.2.2+cp37/warp/codegen.py(107): init
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] /home/paolo/.local/share/ov/pkg/deps/7c44b65c46ba8b7ef0a7f2f8232f2685/extscache/omni.warp-0.2.2+cp37/warp/context.py(252): init
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] /home/paolo/.local/share/ov/pkg/deps/7c44b65c46ba8b7ef0a7f2f8232f2685/extscache/omni.warp-0.2.2+cp37/warp/context.py(302): kernel
2022-08-15 09:29:20 [Error] [omni.kit.app.plugin] executing: Python 0…(5):
Am I making something wrong?
Thankyou
Paolo
Someone on Discord mentioned that you can’t use the += operator. You want to expand that as:
a[i] = a[i] + 1.0
Also, you forgot to include wp.init(). Let me know if that doesn’t work.
Hello Mati,
the error rises only when a decorator @wp.kernel is juxtaposed.
I tried to correct the += operator with = + but no way
I just uninstalled and reinstalled code still no way.
I downloaded an warp example from github and still no way
The returned error is the same:
2022-08-15 20:59:53 [1,062,570ms] [Error] [omni.kit.app.plugin] [py stderr]: OSError: could not get source code
At:
/home/paolo/.local/share/ov/pkg/deps/7817e2526e42b831a0b672f240c251c4/python/lib/python3.7/inspect.py(786): findsource
/home/paolo/.local/share/ov/pkg/deps/7817e2526e42b831a0b672f240c251c4/python/lib/python3.7/inspect.py(955): getsourcelines
/home/paolo/.local/share/ov/pkg/deps/7817e2526e42b831a0b672f240c251c4/python/lib/python3.7/inspect.py(973): getsource
/home/paolo/.local/share/ov/pkg/deps/efa7126ac28229139e663ee7442c7aa9/extscache/omni.warp-0.2.2+cp37/warp/codegen.py(107): init
/home/paolo/.local/share/ov/pkg/deps/efa7126ac28229139e663ee7442c7aa9/extscache/omni.warp-0.2.2+cp37/warp/context.py(252): init
/home/paolo/.local/share/ov/pkg/deps/efa7126ac28229139e663ee7442c7aa9/extscache/omni.warp-0.2.2+cp37/warp/context.py(302): kernel
while the program is now:
import warp as wp
import numpy as np
@wp.kernel
i=wp.tid()
a[i]=a[i] + 1.0
return;
print(“Hello”)
wp.init()
Just to follow-up here. We continued the conversation on Discord. Looks like the issue is that there is a bug with reading warp source code from __main__. The dev team is looking into to and the workaround is to work from within an Extension or OmniGraph node.
ok thankyou for you kind update
Paolo
