I see there are RX FCS errors on those physical interfaces. FCS errors are indication of for CRC errors which are generally layer 1 issue caused by the faulty port on the device or bad cable
You could try the following and see if this helps
Try to reseat the cables
Replace the cable with know good working cable
If problem still exists, please open a case with us and we will help you to resolve this issue
