Dear community,
I just installed PGI on my Windows workstation. My workstation has a Quadro P2000 card.
When I type: pgaccelinfo
I get the following output:
CUDA Driver Version: 9010
Device Number: 0
Device Name: Quadro P2000
Device Revision Number: 6.1
Global Memory Size: 5368709120
Number of Multiprocessors: 8
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 1480 MHz
Execution Timeout: Yes
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: No
Memory Clock Rate: 3504 MHz
Memory Bus Width: 160 bits
L2 Cache Size: 1310720 bytes
Max Threads Per SMP: 2048
Async Engines: 2
Unified Addressing: Yes
Managed Memory: Yes
Concurrent Managed Memory: No
PGI Default Target: -ta=tesla:cc60
So, when I try to compile the Fortran example found on the OpenACC Getting Started Guide (page 24)
I got the following error:
$ pgfortran -acc f1.f90
pgnvd-Error-CUDADIR value is not a directory: C:\PROGRA~1\PGI\win64/2019/cuda/9.1/bin
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (f1.f90: 1)
PGF90/x86-64 Windows 19.4-0: compilation aborted
Any suggestion?
