We are using a custom board based on Jetson AGX Orin Industrial (JetPack 6.2 / Ubuntu 22.04).
During the power cycle stress test, a boot failure occurred.
I only uploaded the logs from the failure event and the previous successful boot.
bootfail-RAS Uncorrectable Error in SNOC.txt (124.3 KB)
This error is not any kind of known issue.
Is your custom board using any USB setting during boot up? Are you sure the device tree for USB part already matching your board design?
I have confirmed that the USB device tree matches the hardware design. Currently, this issue has only been observed on one unit during repeated power cycle testing.
Please check if issue would happen or not if you disable USB in device tree first.
