Error: read variable BootChainFwCurrent failed!
我在orin nx jp5.1.2上编译自己的程序后,启动后执行以下命令会报这样的错,请问这是哪方面的原因?
# nvbootctrl dump-slots-info
Current version: 35.4.1
Capsule update status: 0
Error: invalid current bootloader slot: return(-22)
我烧录的命令是
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
Linux_for_Tegra是在官网下载的内容(Jetson_Linux_R35.4.1_aarch64.tbz2)
只有文件系统是在desktop基础上增加了一些环境依赖
这是我的编译指令
./Linux_for_Tegra/sources/nvbuild.sh -o $PWD/kernel_out
附上启动log
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
      L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.120-rt70-tegra (zme@zme-System-Product-Name) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT RT Wed May 15 09:32:40 CST 2024
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x466eb1f18 SMBIOS=0xffff0000 SMBIOS 3.0=0x447ac0000 MEMATTR=0x44844b018 ESRT=0x447951218 RNG=0x44883f818 MEMRESERVE=0x448454f18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x0000000447951218 to 0x0000000447951250.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000045a800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000473ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000446dd7fff]
[    0.000000]   node   0: [mem 0x0000000446dd8000-0x0000000447018fff]
[    0.000000]   node   0: [mem 0x0000000447019000-0x00000004479effff]
[    0.000000]   node   0: [mem 0x00000004479f0000-0x0000000447a3ffff]
[    0.000000]   node   0: [mem 0x0000000447a40000-0x0000000447a5ffff]
[    0.000000]   node   0: [mem 0x0000000447a60000-0x0000000447acffff]
[    0.000000]   node   0: [mem 0x0000000447ad0000-0x00000004482fffff]
[    0.000000]   node   0: [mem 0x0000000448300000-0x000000044839ffff]
[    0.000000]   node   0: [mem 0x00000004483a0000-0x00000004483bffff]
[    0.000000]   node   0: [mem 0x00000004483c0000-0x00000004483dffff]
[    0.000000]   node   0: [mem 0x00000004483e0000-0x00000004483effff]
[    0.000000]   node   0: [mem 0x00000004483f0000-0x000000044841ffff]
[    0.000000]   node   0: [mem 0x0000000448420000-0x000000044845ffff]
[    0.000000]   node   0: [mem 0x0000000448460000-0x000000044847ffff]
[    0.000000]   node   0: [mem 0x0000000448480000-0x000000044858ffff]
[    0.000000]   node   0: [mem 0x0000000448590000-0x000000044876ffff]
[    0.000000]   node   0: [mem 0x0000000448770000-0x000000044882ffff]
[    0.000000]   node   0: [mem 0x0000000448830000-0x00000004488dffff]
[    0.000000]   node   0: [mem 0x00000004488e0000-0x000000044892ffff]
[    0.000000]   node   0: [mem 0x0000000448930000-0x0000000448b5ffff]
[    0.000000]   node   0: [mem 0x0000000448b60000-0x0000000448beffff]
[    0.000000]   node   0: [mem 0x0000000448bf0000-0x0000000448c3ffff]
[    0.000000]   node   0: [mem 0x0000000448c40000-0x0000000448c6ffff]
[    0.000000]   node   0: [mem 0x0000000448c70000-0x0000000448d0ffff]
[    0.000000]   node   0: [mem 0x0000000448d10000-0x0000000448d5ffff]
[    0.000000]   node   0: [mem 0x0000000448d60000-0x0000000448dfffff]
[    0.000000]   node   0: [mem 0x0000000448e00000-0x00000004492dffff]
[    0.000000]   node   0: [mem 0x00000004492e0000-0x00000004494bffff]
[    0.000000]   node   0: [mem 0x00000004494c0000-0x000000046ab2ffff]
[    0.000000]   node   0: [mem 0x000000046ab30000-0x000000046ab7ffff]
[    0.000000]   node   0: [mem 0x000000046ab80000-0x000000046ea0ffff]
[    0.000000]   node   0: [mem 0x000000046ea10000-0x000000046ea1ffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x0000000473ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000473ffffff]
[    0.000000] On node 0, zone Normal: 480 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 27 pages/cpu s73216 r8192 d29184 u110592
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4066592
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 15620484K/16525440K available (18304K kernel code, 3222K rwdata, 7096K rodata, 3904K init, 1445K bss, 642812K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000661] Console: colour dummy device 80x25
[    0.000708] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000716] pid_max: default: 32768 minimum: 301
[    0.000821] LSM: Security Framework initializing
[    0.000849] Yama: becoming mindful.
[    0.000869] SELinux:  Initializing.
[    0.001008] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001068] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.002219] rcu: Hierarchical SRCU implementation.
[    0.002408] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002863] DTS File Name: /mnt/ssd/work/testorin/orin_jetpack/Linux_for_Tegra/sources/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts
[    0.002867] DTB Build time: May 15 2024 11:54:52
[    0.004162] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0
[    0.004330] EFI runtime services will be disabled.
[    0.004564] smp: Bringing up secondary CPUs ...
[    0.033334] Detected PIPT I-cache on CPU1
[    0.033370] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033402] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062110] Detected PIPT I-cache on CPU2
[    0.062122] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062136] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090815] Detected PIPT I-cache on CPU3
[    0.090825] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090839] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121559] Detected PIPT I-cache on CPU4
[    0.121584] GICv3: CPU4: found redistributor 20000 region 0:0x000000000f540000
[    0.121613] CPU4: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.150357] Detected PIPT I-cache on CPU5
[    0.150368] GICv3: CPU5: found redistributor 20100 region 0:0x000000000f560000
[    0.150383] CPU5: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.179701] Detected PIPT I-cache on CPU6
[    0.179712] GICv3: CPU6: found redistributor 20200 region 0:0x000000000f580000
[    0.179728] CPU6: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.209032] Detected PIPT I-cache on CPU7
[    0.209043] GICv3: CPU7: found redistributor 20300 region 0:0x000000000f5a0000
[    0.209058] CPU7: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.209122] smp: Brought up 1 node, 8 CPUs
[    0.209126] SMP: Total of 8 processors activated.
[    0.209128] CPU features: detected: Privileged Access Never
[    0.209130] CPU features: detected: LSE atomic instructions
[    0.209131] CPU features: detected: User Access Override
[    0.209132] CPU features: detected: 32-bit EL0 Support
[    0.209132] CPU features: detected: Common not Private translations
[    0.209134] CPU features: detected: RAS Extension Support
[    0.209134] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.209135] CPU features: detected: CRC32 instructions
[    0.209136] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.225846] spectre-bhb mitigation disabled by command line option
[    0.225847] spectre-bhb mitigation disabled by command line option
[    0.241162] CPU: All CPU(s) started at EL2
[    0.243111] devtmpfs: initialized
[    0.262373] Registered cp15_barrier emulation handler
[    0.262381] Registered setend emulation handler
[    0.262386] KASLR enabled
[    0.262513] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.262526] futex hash table entries: 2048 (order: 6, 262144 bytes, linear)
[    0.264407] pinctrl core: initialized pinctrl subsystem
[    0.264919] SMBIOS 3.0.0 present.
[    0.264925] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
[    0.265275] NET: Registered protocol family 16
[    0.266258] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.266369] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.266469] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.266493] audit: initializing netlink subsys (disabled)
[    0.266590] audit: type=2000 audit(0.264:1): state=initialized audit_enabled=0 res=1
[    0.266803] thermal_sys: Registered thermal governor 'step_wise'
[    0.266806] thermal_sys: Registered thermal governor 'power_allocator'
[    0.266808] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.267855] cpuidle: using governor menu
[    0.268019] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.268108] ASID allocator initialised with 32768 entries
[    0.268251] Serial: AMBA PL011 UART driver
[    0.270341] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.270362] Tegra reboot handler registered.
[    0.289964] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2c10000
[    0.289973] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2c20000
[    0.289980] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2c30000
[    0.289991] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2c40000
[    0.289996] mc: mapped MMIO address: 0xffff800010c30000 -> 0x2c50000
[    0.290001] mc: mapped MMIO address: 0xffff800010c50000 -> 0x2b80000
[    0.290007] mc: mapped MMIO address: 0xffff800010c70000 -> 0x2b90000
[    0.290012] mc: mapped MMIO address: 0xffff800010c90000 -> 0x2ba0000
[    0.290016] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x2bb0000
[    0.290022] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1700000
[    0.290026] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1710000
[    0.290031] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1720000
[    0.290036] mc: mapped MMIO address: 0xffff800010d30000 -> 0x1730000
[    0.290040] mc: mapped MMIO address: 0xffff800010d50000 -> 0x1740000
[    0.290045] mc: mapped MMIO address: 0xffff800010d70000 -> 0x1750000
[    0.290049] mc: mapped MMIO address: 0xffff800010d90000 -> 0x1760000
[    0.290053] mc: mapped MMIO address: 0xffff800010db0000 -> 0x1770000
[    0.290061] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.290084] mc-err: mcerr ops are set to t23x
[    0.291118] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[    0.291134] printk: console [ttyAMA0] enabled
[    0.296024] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.296027] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.296029] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.296029] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.298027] ACPI: Interpreter disabled.
[    0.298486] ddr-vddq: supplied by vdd-5v
[    0.298649] ddr-vdd2: supplied by vdd-5v
[    0.298770] vdd-AO-1v2: supplied by vdd-5v
[    0.298889] vdd-3v3: supplied by vdd-5v
[    0.299054] vdd-rtc: supplied by vdd-AO-1v2
[    0.299176] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    0.299283] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    0.299545] vdd-1v8: supplied by vdd-3v3-sys
[    0.299657] vdd-3v3-AO: supplied by vdd-5v-sys
[    0.299757] vdd-av10-hub: supplied by vdd-5v-sys
[    0.299863] vdd-vbus-a: supplied by vdd-5v-sys
[    0.299960] vdd-vbus-b: supplied by vdd-5v-sys
[    0.300071] vdd-3v3-dp: supplied by vdd-3v3-sys
[    0.300370] iommu: Default domain type: Translated
[    0.300425] eventlib_kernel: keventlib is initialized, test id: 0
[    0.300653] SCSI subsystem initialized
[    0.300742] usbcore: registered new interface driver usbfs
[    0.300756] usbcore: registered new interface driver hub
[    0.300768] usbcore: registered new device driver usb
[    0.300958] mc: Linux media interface: v0.10
[    0.300975] videodev: Linux video capture interface: v2.00
[    0.301122] pps_core: LinuxPPS API ver. 1 registered
[    0.301123] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.301128] PTP clock support registered
[    0.301348] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    0.301370] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    0.302776] FPGA manager framework
[    0.302814] Advanced Linux Sound Architecture Driver Initialized.
[    0.303138] Bluetooth: Core ver 2.22
[    0.303152] NET: Registered protocol family 31
[    0.303153] Bluetooth: HCI device and connection manager initialized
[    0.303160] Bluetooth: HCI socket layer initialized
[    0.303163] Bluetooth: L2CAP socket layer initialized
[    0.303170] Bluetooth: SCO socket layer initialized
[    0.303732] camchar: rtcpu character device driver loaded
[    0.304207] clocksource: Switched to clocksource arch_sys_counter
[    0.467028] VFS: Disk quotas dquot_6.6.0
[    0.467071] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.467422] pnp: PnP ACPI: disabled
[    0.470341] la/ptsa driver initialized.
[    0.470414] NET: Registered protocol family 2
[    0.470909] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.473190] tcp_listen_portaddr_hash hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.473456] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.473586] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes, linear)
[    0.475429] TCP: Hash tables configured (established 131072 bind 65536)
[    0.475556] UDP hash table entries: 8192 (order: 8, 1048576 bytes, linear)
[    0.476097] UDP-Lite hash table entries: 8192 (order: 8, 1048576 bytes, linear)
[    0.476766] NET: Registered protocol family 1
[    0.477034] RPC: Registered named UNIX socket transport module.
[    0.477036] RPC: Registered udp transport module.
[    0.477037] RPC: Registered tcp transport module.
[    0.477037] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.477045] PCI: CLS 0 bytes, default 64
[    0.477161] Trying to unpack rootfs image as initramfs...
[    0.608178] Freeing initrd memory: 9552K
[    0.610459] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.611181] Initialise system trusted keyrings
[    0.611356] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[    0.614292] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.614686] NFS: Registering the id_resolver key type
[    0.614703] Key type id_resolver registered
[    0.614704] Key type id_legacy registered
[    0.614749] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.614757] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.614768] ntfs: driver 2.1.32 [Flags: R/W].
[    0.626865] NET: Registered protocol family 38
[    0.626870] Key type asymmetric registered
[    0.626873] Asymmetric key parser 'x509' registered
[    0.626897] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    0.626965] io scheduler mq-deadline registered
[    0.626968] io scheduler kyber registered
[    0.632545] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.632580] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.632599] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.632614] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    0.635261] tegra_dc_assign_hw_data: no matching compatible node
[    0.635263] tegradccommon module_init failed
[    0.635266] tegradc module_init failed
[    0.635538] EINJ: ACPI disabled.
[    0.637143] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.637149] tegra-pmc: ### PMC reset source: MAINSWRST
[    0.637151] tegra-pmc: ### PMC reset level: L1
[    0.637152] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.638483] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.639602] printk: console [ttyTCU0] enabled
[    0.640152] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.640156] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.640159] arm-smmu 12000000.iommu:         stage 1 translation
[    0.640160] arm-smmu 12000000.iommu:         stage 2 translation
[    0.640161] arm-smmu 12000000.iommu:         nested translation
[    0.640164] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.640167] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.643180] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    0.643182] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.643185] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.644095] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.644097] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.644100] arm-smmu 10000000.iommu:         stage 1 translation
[    0.644100] arm-smmu 10000000.iommu:         stage 2 translation
[    0.644101] arm-smmu 10000000.iommu:         nested translation
[    0.644109] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.644111] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.647069] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    0.647072] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.647073] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.647564] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.647567] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.647569] arm-smmu 8000000.iommu:  stage 1 translation
[    0.647570] arm-smmu 8000000.iommu:  stage 2 translation
[    0.647571] arm-smmu 8000000.iommu:  nested translation
[    0.647573] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.647575] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.650562] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    0.650564] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.650566] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.651348] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    0.653241] tegra_profiler: version: 1.151, samples/io: 51/30
[    0.653307] tegra_profiler: auth: init
[    0.653612] nvsciipc: loaded module
[    0.655307] tun: Universal TUN/TAP device driver, 1.6
[    0.655764] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.655767] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.655793] e1000e: Intel(R) PRO/1000 Network Driver
[    0.655794] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.655809] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.655811] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.655980] PPP generic driver version 2.4.2
[    0.656028] PPP BSD Compression module registered
[    0.656031] PPP Deflate Compression module registered
[    0.656045] PPP MPPE Compression module registered
[    0.656069] usbcore: registered new interface driver r8152
[    0.656085] usbcore: registered new interface driver asix
[    0.656093] usbcore: registered new interface driver ax88179_178a
[    0.656102] usbcore: registered new interface driver cdc_ether
[    0.656110] usbcore: registered new interface driver net1080
[    0.656116] usbcore: registered new interface driver cdc_subset
[    0.656127] usbcore: registered new interface driver zaurus
[    0.656141] usbcore: registered new interface driver cdc_ncm
[    0.656147] usbcore: registered new interface driver aqc111
[    0.656316] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.656328] ohci-pci: OHCI PCI platform driver
[    0.656347] ohci-platform: OHCI generic platform driver
[    0.656657] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    0.657296] usbcore: registered new interface driver uas
[    0.657314] usbcore: registered new interface driver usb-storage
[    0.657479] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    0.657858] mousedev: PS/2 mouse device common for all mice
[    0.657880] usbcore: registered new interface driver xpad
[    0.659745] tegra_rtc c2a0000.rtc: registered as rtc1
[    0.660020] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:19 UTC (19)
[    0.660038] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    0.660177] i2c /dev entries driver
[    0.660307] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    0.660537] tegra-i2c c240000.i2c: Adding to iommu group 2
[    0.660604] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    0.660657] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    0.660714] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    0.660765] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    0.660815] tegra-i2c c250000.i2c: Adding to iommu group 2
[    0.660881] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    0.664673] device-mapper: uevent: version 1.0.3
[    0.664778] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    0.665824] sdhci: Secure Digital Host Controller Interface driver
[    0.665826] sdhci: Copyright(c) Pierre Ossman
[    0.665826] Synopsys Designware Multimedia Card Interface Driver
[    0.665906] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.666340] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    0.667007] tegra-bpmp bpmp: firmware: 029a50a8fb4897d35f94-925eece486b
[    0.667966] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    0.668252] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    0.671423] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    0.671449] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[    1.839937] hid: raw HID events driver (C) Jiri Kosina
[    1.840552] usbcore: registered new interface driver usbhid
[    1.840555] usbhid: USB HID core driver
[    1.841019] tegra-dce d800000.dce: Adding to iommu group 3
[    1.843691] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    1.844453] tegra234-aon c000000.aon: Adding to iommu group 4
[    1.845846] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    1.845854] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    1.845884] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    1.845993] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    1.846124] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    1.846130] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    1.846136] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    1.846138] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    1.846140] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    1.846262] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    1.846272] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    1.846277] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    1.846505] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    1.846605]  c000000.aon:hsp: probed
[    1.846826] tegra234-aon c000000.aon: init done
[    1.847120] tegra23x-psc e860000.psc: Adding to iommu group 5
[    1.848397] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    1.848401] tegra23x-psc e860000.psc: init done
[    1.848628] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[    1.849961] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    1.853569] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    1.853632] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    1.853990] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    1.854420] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    1.854896] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    1.854944] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    1.854974] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    1.855972] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (112)
[    1.855974] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    1.856356] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856366] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856372] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856373] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856374] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[    1.856375] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856389] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856391] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.856392] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    1.858414] t19x_cache tegra-cache: probed
[    1.859228] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    1.866591] optee: probing for conduit method.
[    1.866614] optee: revision 3.21 (d8269f24)
[    1.925346] optee: dynamic shared memory is enabled
[    1.925468] optee: initialized driver
[    1.937553] nvpmodel: initialized successfully
[    1.937786] tegra_hv: get_hvd: not initialized yet
[    1.937797] user_ivc_mempool: hypervisor not present
[    1.938471] usbcore: registered new interface driver snd-usb-audio
[    1.939355] u32 classifier
[    1.939359]     input device check on
[    1.939360]     Actions configured
[    1.939510] Initializing XFRM netlink socket
[    1.939973] NET: Registered protocol family 10
[    1.941377] Segment Routing with IPv6
[    1.941425] NET: Registered protocol family 17
[    1.941443] NET: Registered protocol family 15
[    1.941498] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.941926] Bluetooth: RFCOMM socket layer initialized
[    1.941947] Bluetooth: RFCOMM ver 1.11
[    1.941957] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.941964] Bluetooth: HIDP socket layer initialized
[    1.942911] 9pnet: Installing 9P2000 support
[    1.942968] Key type dns_resolver registered
[    1.944055] printk: console [ttyAMA0]: printing thread started
[    1.944928] printk: console [ttyTCU0]: printing thread started
[    1.944991] Loading compiled-in X.509 certificates
[    1.954469] Loaded X.509 cert 'Build time autogenerated kernel key: 341a2fd3666a0ef4cd238ea20585175c5977137d'
[    1.955000] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[    1.962761] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    1.963692] tegra194-pcie 14160000.pcie: Adding to iommu group 8
[    1.970565] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    1.970975] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[    1.977862] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    1.978227] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[    1.985002] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    2.021781] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[    2.025417] host1x 13e40000.host1x: Adding to iommu group 12
[    2.055855] host1x 13e40000.host1x: initialized
[    2.056254] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[    2.056845] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    2.058213] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[    2.059190] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    2.060547] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[    2.061112] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    2.062424] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[    2.062959] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    2.064290] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[    2.064918] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    2.066242] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[    2.066509] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    2.067838] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[    2.068154] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    2.069488] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[    2.069764] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    2.071120] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[    2.071379] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    2.072734] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[    2.072987] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    2.074314] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[    2.074573] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    2.075900] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[    2.076222] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    2.077540] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[    2.077793] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    2.079138] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[    2.079391] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    2.080762] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[    2.081029] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    2.082359] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[    2.082628] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    2.083991] falcon 15340000.vic: Adding to iommu group 29
[    2.089133] falcon 15340000.vic: initialized
[    2.089570] falcon 15380000.nvjpg: Adding to iommu group 30
[    2.092530] falcon 15380000.nvjpg: initialized
[    2.092683] falcon 15540000.nvjpg1: Adding to iommu group 31
[    2.095360] falcon 15540000.nvjpg1: initialized
[    2.095506] falcon 154c0000.nvenc: Adding to iommu group 32
[    2.100246] falcon 154c0000.nvenc: initialized
[    2.100410] falcon 15a50000.ofa: Adding to iommu group 33
[    2.103428] falcon 15a50000.ofa: initialized
[    2.103573] nvdec 15480000.nvdec: Adding to iommu group 34
[    2.110243] nvdec 15480000.nvdec: initialized
[    2.110381] tsec 15500000.tsec: Adding to iommu group 35
[    2.114810] tsec 15500000.tsec: initialized
[    2.117798] gic 2a41000.agic-controller: GIC IRQ controller registered
[    2.128671] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    2.139421] gpio-397 (camera-control-output-low): hogged as output/low
[    2.139468] gpio-486 (camera-control-output-low): hogged as output/low
[    2.140543] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    2.141452] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    2.141635] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.142199] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.142855] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.143308] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    2.145537] tegra194-isp5 14800000.isp: Adding to iommu group 36
[    2.148877] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    2.149042] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    2.149140] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    2.149148] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    2.149327] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[    2.149906] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[    2.150413] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    2.150553] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    2.150653] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    2.150775] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    2.150852] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    2.150984] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    2.151105] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[    2.151408] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    2.151528] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[    2.151793] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    2.151901] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[    2.152148] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    2.152247] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[    2.152514] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    2.152620] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[    2.152911] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    2.153015] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[    2.153277] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    2.153376] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[    2.153666] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    2.153777] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[    2.154019] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    2.154140] pva 16000000.pva0: Adding to iommu group 47
[    2.158599] pva 16000000.pva0: initialized
[    2.163997] nvdla 15880000.nvdla0: Adding to iommu group 48
[    2.168126] nvdla 15880000.nvdla0: initialized
[    2.169951] nvdla 158c0000.nvdla1: Adding to iommu group 49
[    2.173967] nvdla 158c0000.nvdla1: initialized
[    2.175837] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    2.176850] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    2.177118] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    2.177124] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    2.177343] serial-tegra 3100000.serial: Adding to iommu group 2
[    2.177729] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    2.178224] serial-tegra 3130000.serial: Adding to iommu group 2
[    2.178527] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[    2.178915] serial-tegra 3140000.serial: Adding to iommu group 2
[    2.179201] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[    2.196928] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    2.196939] tegra-xusb 3610000.xhci: xHCI Host Controller
[    2.196981] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    2.197849] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    2.197972] tegra-xusb 3610000.xhci: irq 229, io mem 0x03610000
[    2.198369] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.198375] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.198377] usb usb1: Product: xHCI Host Controller
[    2.198381] usb usb1: Manufacturer: Linux 5.10.120-rt70-tegra xhci-hcd
[    2.198382] usb usb1: SerialNumber: 3610000.xhci
[    2.198788] hub 1-0:1.0: USB hub found
[    2.198817] hub 1-0:1.0: 4 ports detected
[    2.199118] tegra-xusb 3610000.xhci: xHCI Host Controller
[    2.199126] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    2.199133] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    2.199217] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.199222] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.199223] usb usb2: Product: xHCI Host Controller
[    2.199224] usb usb2: Manufacturer: Linux 5.10.120-rt70-tegra xhci-hcd
[    2.199226] usb usb2: SerialNumber: 3610000.xhci
[    2.199402] hub 2-0:1.0: USB hub found
[    2.199419] hub 2-0:1.0: 4 ports detected
[    2.219355] i2c i2c-2: Added multiplexed i2c bus 9
[    2.219667] i2c i2c-2: Added multiplexed i2c bus 10
[    2.219673] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    2.219945] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    2.232076] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2006000 KHz, changing to: 1984000 KHz
[    2.233428] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2010000 KHz, changing to: 1984000 KHz
[    2.234011] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    2.234700] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    2.235496] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    2.235506] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    2.235512] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    2.235515] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    2.340210] tegra194-pcie 14100000.pcie: Link up
[    2.341382] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    2.341384] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.341388] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    2.341390] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    2.341391] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    2.341440] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    2.341610] pci 0001:00:00.0: PME# supported from D0 D3hot
[    2.345748] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    2.345907] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.346106] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    2.347203] pci 0001:01:00.0: supports D1 D2
[    2.347205] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.351316] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    2.351319] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.351323] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    2.351425] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.351456] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    2.351459] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    2.351464] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    2.351478] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    2.351552] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    2.351803] pcieport 0001:00:00.0: Adding to iommu group 7
[    2.352228] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    2.352896] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    2.353630] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    2.355131] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    2.355139] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    2.355145] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    2.355148] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    2.460209] tegra194-pcie 14160000.pcie: Link up
[    2.460212] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.461229] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    2.461233] pci_bus 0004:00: root bus resource [bus 00-ff]
[    2.461235] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    2.461237] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    2.461239] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    2.461276] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    2.461421] pci 0004:00:00.0: PME# supported from D0 D3hot
[    2.465217] pci 0004:01:00.0: [126f:2263] type 00 class 0x010802
[    2.465402] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    2.470351] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    2.470356] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    2.470441] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    2.470446] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    2.470459] pci 0004:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    2.470522] pci 0004:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    2.470766] pcieport 0004:00:00.0: Adding to iommu group 8
[    2.471392] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    2.472373] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    2.472668] nvme 0004:01:00.0: Adding to iommu group 8
[    2.473087] nvme nvme0: pci function 0004:01:00.0
[    2.473170] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    2.473676] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    2.476149] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    2.476158] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    2.476163] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    2.476166] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    2.485588] nvme nvme0: missing or invalid SUBNQN field.
[    2.498773] nvme nvme0: allocated 64 MiB host memory buffer.
[    2.515953] nvme nvme0: 8/0/0 default/read/poll queues
[    2.523161]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    2.632832] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[    2.632836] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.632838] usb 1-2: Product: 4-Port USB 2.0 Hub
[    2.632839] usb 1-2: Manufacturer: Generic
[    2.634200] hub 1-2:1.0: USB hub found
[    2.635226] hub 1-2:1.0: 4 ports detected
[    2.764363] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    2.916317] usb 1-3: New USB device found, idVendor=0bda, idProduct=c822, bcdDevice= 0.00
[    2.916322] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.916324] usb 1-3: Product: Bluetooth Radio
[    2.916325] usb 1-3: Manufacturer: Realtek
[    2.916327] usb 1-3: SerialNumber: 00e04c000001
[    3.328207] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[    3.445815] usb 1-2.3: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10
[    3.445820] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.445822] usb 1-2.3: Product: Usb Mouse
[    3.445824] usb 1-2.3: Manufacturer: SIGMACHIP
[    3.451092] input: SIGMACHIP Usb Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:1C4F:0034.0001/input/input0
[    3.451196] hid-generic 0003:1C4F:0034.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-3610000.xhci-2.3/input0
[    3.588441] tegra194-pcie 141e0000.pcie: Phy link never came up
[    3.588535] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    3.588539] pci_bus 0007:00: root bus resource [bus 00-ff]
[    3.588544] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    3.588546] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    3.588548] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[    3.588594] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    3.588744] pci 0007:00:00.0: PME# supported from D0 D3hot
[    3.596158] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    3.596177] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    3.596456] pcieport 0007:00:00.0: Adding to iommu group 9
[    3.597093] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[    3.598504] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[    3.598739] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    3.598832] pci 0007:00:00.0: Removing from iommu group 9
[    3.598841] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    3.600418] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    3.600678] vdd-3v3-sd: supplied by vdd-3v3
[    3.602150] tegra194-isp5 14800000.isp: initialized
[    3.604407] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    3.604498] (NULL device *): fops function table already registered
[    3.605245] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    3.605714] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    3.606025] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[    3.712679] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[    3.712696] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    3.712704] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    3.712707] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    3.820212] tegra194-pcie 140a0000.pcie: Link up
[    3.821264] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    3.821267] pci_bus 0008:00: root bus resource [bus 00-ff]
[    3.821269] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    3.821271] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    3.821272] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    3.821313] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    3.821460] pci 0008:00:00.0: PME# supported from D0 D3hot
[    3.825428] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    3.825571] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    3.825751] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    3.825868] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    3.826889] pci 0008:01:00.0: supports D1 D2
[    3.826892] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    3.830980] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    3.830983] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    3.830987] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    3.831080] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    3.831171] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    3.831199] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    3.831201] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    3.831205] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    3.831219] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    3.831285] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    3.831532] pcieport 0008:00:00.0: Adding to iommu group 10
[    3.832475] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[    3.833075] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[    3.834882] irq: IRQ304: trimming hierarchy from :pmc@c360000
[    3.835448] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[    3.835807] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    3.836585] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[    3.837063] tegra-se-nvhost 15810000.se: initialized
[    3.845857] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    3.845944] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[    3.846414] tegra-se-nvhost 15820000.se: initialized
[    3.847491] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    3.847570] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[    3.847894] tegra-se-nvhost 15840000.se: initialized
[    3.849139] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    3.849836] tegra_actmon d230000.actmon: in actmon_register()...
[    3.850005] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    3.850430] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    3.850660] hvc_sysfs: hypervisor is not present
[    3.884651] ALSA device list:
[    3.884655]   No soundcards found.
[    3.891351] Freeing unused kernel memory: 3904K
[    3.924386] Run /init as init process
[    3.952286] Root device found: nvme0n1p1
[    3.957749] Found dev node: /dev/nvme0n1p1
[    3.966968] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    3.969365] Rootfs mounted over nvme0n1p1
[    3.977840] Switching from initrd to actual rootfs
[    4.056103] systemd[1]: System time before build time, advancing clock.
[    4.158817] request_module fs-efivarfs succeeded, but still no fs?
[    4.173487] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    4.173982] systemd[1]: Detected architecture arm64.
[    4.276618] systemd[1]: Set hostname to <zme-0010-test>.
[    4.417500] random: systemd: uninitialized urandom read (16 bytes read)
[    4.417561] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    4.417565] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    4.418578] systemd[1]: Created slice system-modprobe.slice.
[    4.488296] random: systemd: uninitialized urandom read (16 bytes read)
[    4.488699] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.580436] random: systemd: uninitialized urandom read (16 bytes read)
[    4.580790] systemd[1]: Created slice User and Session Slice.
[    4.664531] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.732500] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.771981] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.844464] systemd[1]: Reached target Local Encrypted Volumes.
[    4.916463] systemd[1]: Reached target User and Group Name Lookups.
[    4.922702] random: crng init done
[    4.922705] random: 5 urandom warning(s) missed due to ratelimiting
[    5.004434] systemd[1]: Reached target Remote File Systems.
[    5.092428] systemd[1]: Reached target Slices.
[    5.164437] systemd[1]: Reached target Swap.
[    5.240624] systemd[1]: Listening on Syslog Socket.
[    5.304556] systemd[1]: Listening on fsck to fsckd communication Socket.
[    5.380518] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    5.448633] systemd[1]: Listening on Journal Audit Socket.
[    5.532557] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.624518] systemd[1]: Listening on Journal Socket.
[    5.704526] systemd[1]: Listening on udev Control Socket.
[    5.768491] systemd[1]: Listening on udev Kernel Socket.
[    5.801703] systemd[1]: Mounting Huge Pages File System...
[    5.869552] systemd[1]: Mounting POSIX Message Queue File System...
[    5.945961] systemd[1]: Mounting Kernel Debug File System...
[    6.014186] systemd[1]: Mounting Kernel Trace File System...
[    6.086449] systemd[1]: Starting Journal Service...
[    6.154171] systemd[1]: Starting Set the console keyboard layout...
[    6.214170] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    6.301842] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    6.372304] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    6.373770] systemd[1]: Starting Load Kernel Module efi_pstore...
[    6.441870] systemd[1]: Starting Load Kernel Module pstore_blk...
[    6.509604] systemd[1]: Starting Load Kernel Module pstore_zone...
[    6.565910] systemd[1]: Starting Load Kernel Module ramoops...
[    6.633666] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    6.709722] systemd[1]: Started Nameserver information manager.
[    6.780517] systemd[1]: Reached target Network (Pre).
[    6.845437] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.845499] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    6.847971] systemd[1]: Starting Load Kernel Modules...
[    6.900333] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    6.901064] nvmap_page_pool_init: Total RAM pages: 3974021
[    6.901067] nvmap_page_pool_init: nvmap page pool size: 496752 pages (1940 MB)
[    6.901311] nvmap_background_zero_thread: PP zeroing thread starting.
[    6.913943] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.924118] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[    6.994239] systemd[1]: Starting udev Coldplug all Devices...
[    7.075261] systemd[1]: Started Journal Service.
[    7.723237] systemd-journald[462]: Received client request to flush runtime journal.
[    8.066067] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    8.066067]
[    9.594622] spi-tegra114 3210000.spi: Adding to iommu group 2
[    9.695995] spi-tegra114 3230000.spi: Adding to iommu group 2
[   10.518145] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   10.523254] imx219 9-0010: board setup failed
[   10.529198] imx219: probe of 9-0010 failed with error -121
[   10.540897] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   10.545998] imx219 10-0010: board setup failed
[   10.559993] imx219: probe of 10-0010 failed with error -121
[   10.733573] fusb301 1-0025: toggle_time(0) is not updated
[   10.928733] bluetooth hci0: Direct firmware load for rtl_bt/rtl8822cu_fw.bin failed with error -2
[   10.928738] bluetooth hci0: Falling back to sysfs fallback for: rtl_bt/rtl8822cu_fw.bin
[   12.196901] using random self ethernet address
[   12.196908] using random host ethernet address
[   13.544283] using random self ethernet address
[   13.544288] using random host ethernet address
[   13.667555] Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8822cu_fw.bin not found
[   18.284937] CPU4: shutdown
[   18.400974] CPU5: shutdown
[   18.488601] CPU6: shutdown
[   18.573340] IRQ 117: no longer affine to CPU7
[   18.573700] CPU7: shutdown
Ubuntu 20.04.6 LTS zme-0010-test ttyTCU0
zme-0010-test login: zme (automatic login)
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.10.120-rt70-tegra aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
麻煩至少先確定用default BSP和kernel會不會有這樣的問題
我做了以下测试
使用Jetson_Linux_R35.4.1_aarch64.tbz2解压后进行编译。
源码使用的是kernel_src.tbz2解压得到的。
经过编译后将kernel_out/arch/arm64/boot/Image替换到设备中可以读取到正确的slot信息并且可以正常切换。如果我加上rt补丁就会出现之前的错误,这是rt本身不支持ab分区吗?
以下是我的执行步骤
1.下载Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2解压
2.cd Linux_for_Tegra/source
tar -xjf /home/zme/work/robot/orin_jetpack/public_sources/Linux_for_Tegra/source/public/kernel_src.tbz2
CROSS_COMPILE_AARCH64=/mnt/ssd/work/testorin_will_delete/orin_jetpack_origin/aarch64--glibc--stable-final/bin/aarch64-buildroot-linux-gnu-
CROSS_COMPILE_AARCH64_PATH=/mnt/ssd/work/testorin_will_delete/orin_jetpack_origin/aarch64--glibc--stable-final/
./nvbuild.sh -o /mnt/ssd/work/testorin_will_delete/orin_jetpack_origin/Linux_for_Tegra/source/kernel_out
cp kernel_out/arch/arm64/boot/dts/nvidia/* ../../Linux_for_Tegra/kernel/dtb/
cp kernel_out/arch/arm64/boot/Image ../../Linux_for_Tegra/kernel/
sudo tar xpf /home/zme/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2 -C ../../Linux_for_Tegra/rootfs/
这种情况只将Image复制到指定开发板位置,重启后slot信息正常。
./kernel/kernel-5.10/scripts/rt-patch.sh apply-patches
如果加上rt补丁就会出现错误
你有連kernel modules一起裝嗎
我們的文件裡應該很清楚的有寫這一步 但是我看你的指令只有裝kernel image
還有你根本連sudo ./apply_binaries.sh都沒做 你確定這樣可以燒 可以開機?
你指的应该是这一步吗?
sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install INSTALL_MOD_PATH=/Linux_for_Tegra/rootfs/
我之前的系统都执行过的,他会在Linux_for_Tegra/rootfs/usr/lib/modules/5.10.120-rt70-tegra/kernel/下安装许多的ko文件,我尝试将之前的的系统rt补丁去掉也会正常显示slot信息。
因为我只使用default的Linux_for_Tegra和kernel-5.10用来生成kernel Image进行了测试,因此这里没有文件系统相关的操作。我们完整的工程构建是包含了这一步的
这是我们的编译步骤
這句是什麼意思
你可以用35.5也測試一下嗎?
我在default的BSP做完测试后发现更改Image能够不报错,因此在我们实际的工程中替换了Image,也能够正常查看slot信息。这里的之前的系统就是我们实际使用的工程。
我稍后测试下35.5是否会有相同情况
我试了下使用5.1.3的rt patch,似乎也是有问题的
root@zme-0test513:/home/zme# nvbootctrl dump-slots-info
Current version: 35.5.0
Capsule update status: 0
Error: read variable BootChainFwCurrent failed!
Error: invalid current bootloader slot: return(-22)
文件系统,kernel源码都是35.5中下载的压缩包解压出来的。
要不你也试一试有没有这样的问题?
我試過似乎會有一樣的情況
你可不可以試試看不用RT kernel 只是改kernel suffix的話會不會有一樣的問題
把nvbuild.sh裡的LOCALVERSION="-tegra"改掉
還有36.3有pre-built RT kernel 麻煩也測試一下
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/SoftwarePackagesAndTheUpdateMechanism.html#real-time-kernel-using-ota-update
麻煩看一下這兩篇
https://git.kernel.org/pub/scm/linux/kernel/git/rt/linux-rt-devel.git/commit/?h=linux-5.4.y-rt-rebase&id=ba7585a4a5580b4cba26ebe76050bd2ef1148948
https://git.kernel.org/pub/scm/linux/kernel/git/rt/linux-rt-devel.git/commit/?h=linux-5.4.y-rt-rebase&id=0728d54203b80b7de2391b34976b6838a6dbace0
這是upstream Linux kernel的問題
nvbootctrl dump-slots-info會失敗是因為efivarfs沒有被mount起來 而和bootloader有關的資訊都存在efivarfs裡面
會mount不起來是因為EFI相關的函式載入時間太久 所以在kernel裡預設被關掉
可以在kernel cmdline裡加上efi=runtime把它手動開起來
我不確定具體是哪一版,但是這個設定在後面版本的kernel又被打開了,所以36.3上沒有這個問題
Please take a look at these two kernel commits:
It’s an issue in the upstream Linux kernel.
nvbootctrl dump-slots-infofails because efivarfs is not mounted, and all bootloader information that nvbootctrl needs is stored in efivarfs.
efivarfs is not mounted because kernel developers think that these EFI related functions take too long to initialize, not meeting the real time standards, so they are simply disabled.
You can add efi=runtime to kernel cmdline, as specified in /boot/extlinux/extlinux.conf to manually enable it.
This config is enabled again in later kernel versions, so you don’t need this on 36.3.
抱歉,最近有些忙,没有及时回复
感谢解答我的疑问,我们暂时应该不会去切换到36.3,我会试一试将efi=runtime加上测试一下。
nvidia@tegra-ubuntu:~$ uname -r
5.10.192-rt96-tegra
nvidia@tegra-ubuntu:~$ sudo nvbootctrl dump-slots-info
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0,             status: normal
slot: 1,             status: normal
nvidia@tegra-ubuntu:~$ cat /proc/cmdline
root=PARTUUID=1d09af8c-1dd9-4830-b0d5-bc2120292186 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb efi=runtime
我昨天驗證過是沒問題的
你是怎么修改的cmdline,我修改了tegra234-cvm-p3767.dtsi的bootargs为
	chosen {
		bootargs ="console=ttyTCU0,115200 efi=runtime";
		board-has-eeprom;
		nvidia,tegra-joint_xpu_rail;
编译设备树并将设备树放到开发板 的/boot/dtb/kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
重启设备后为何cat /proc/cmdline没有增加efi=runtime
不是改device tree…
麻煩修改/boot/extlinux/extlinux.conf 加在APPEND ${cbootargs}那一行後面
像我測試用的長這樣
LABEL real-time
      MENU LABEL real-time kernel
      LINUX /boot/Image.realtime
      FDT /boot/dtb/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
      INITRD /boot/initrd
      APPEND ${cbootargs} root=PARTUUID=1d09af8c-1dd9-4830-b0d5-bc2120292186 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb efi=runtime
感谢指导,现在这个功能ok了
