Please help me.
i use redshift render for cinema 4D r.20
i see error:
Error: Redshift failed to init the cuda driver api
My Hardware is
i-mac Late 2012 27" inch
Nvidia GeForce GTX 675 Mx
CUDA Driver Version 418.163
GPU Driver Version 355.1.10.10.20.111
Why i can’t use Redshift Render
i have the same issue
anyone help
I have the same issue, did anyone figure out why this is happening?
I get this error:
Warning - Failed to init CUDA (CUDA_ERROR_NO_DEVICE)
GPU Version: 545.84
CUDA Driver Version: 12.3.68
CUDA File Version: 31.0.15.4584
I am running on Maxon One Subscription, so i have redshift
Specs:
- MSI Armor 8GB Nvidia RTX 2070
- Intel core i9-13900k
- G.Skill Trident Z5 RGB DDR5-6400 BK C32 DC - 64GB
- ROG STRIX Z790-E GAMING WIFI
Here is the error log from Cinema 4D 2024
I pasted it here in-case the image doesn’t show correctly.
16:19:21 1307MB INFO: Redshift for Cinema 4D 2024.0.0 running on 2024.1.0
16:19:21 1307MB INFO: Version 3.5.20, Oct 10 2023
16:19:21 1307MB INFO: Revision: 92034e8c9, Tue, 3 Oct 2023 13:34:42 +0300
16:19:21 1307MB INFO: Build: Release
16:19:21 1307MB DETAILED: Plugin path: C:\Program Files\Maxon Cinema 4D 2024\plugins\Redshift
16:19:21 1307MB DETAILED: Plugin resource path: C:\Program Files\Maxon Cinema 4D 2024\plugins\Redshift\res
16:19:21 1307MB DETAILED: Local data path: C:\ProgramData\Redshift
16:19:21 1307MB DETAILED: Core data path: C:\ProgramData\Redshift
16:19:21 1307MB DETAILED: Primary license path: C:\ProgramData\Redshift
16:19:21 1307MB DETAILED: Procedurals path: C:\ProgramData\Redshift\Procedurals
16:19:21 1307MB DETAILED: Preferences file: C:\ProgramData\Redshift\preferences.xml
16:19:21 1307MB DETAILED: Application path: C:\Program Files\Maxon Cinema 4D 2024\Cinema 4D.exe
16:19:21 1307MB DETAILED: Profile path: C:\Users\MyUser\AppData\Roaming\Maxon\Maxon Cinema 4D 2024_A5DBFF93
16:19:21 1307MB DETAILED: Module paths: C:\Program Files\Maxon Cinema 4D 2024\corelibs C:\Program Files\Maxon Cinema 4D 2024\plugins C:\Users\MyUser\AppData\Roaming\Maxon\Maxon Cinema 4D 2024_A5DBFF93\plugins
16:19:23 1370MB DETAILED: Language: C4D:en-US Core:en-US
16:19:23 1403MB DEBUG: Plugin Cache Location: C:\Users\MyUser\AppData\Local\Redshift\Cache\Textures
16:19:23 1488MB INFO: Session: 2023-10-25 16:19:23
16:19:23 1488MB INFO: Initializing Renderer
16:19:23 1488MB DEBUG: Querying texture cache budget from preferences.xml: 32 GB
16:19:23 1488MB DEBUG: Querying cache path from preferences.xml: %LOCALAPPDATA%\Redshift\Cache
16:19:23 1488MB DEBUG: Creating cache path C:\Users\MyUser\AppData\Local\Redshift\Cache
16:19:23 1488MB DEBUG: Enforcing shader cache budget...
16:19:23 1488MB DEBUG: Enforcing texture cache budget...
16:19:23 1488MB DEBUG: Collecting files...
16:19:23 1488MB DEBUG: Total size for 22 files 499.19MB (budget 32768.00MB)
16:19:23 1488MB DEBUG: Under budget. Done.
16:19:23 1488MB DEBUG: Creating mesh cache...
16:19:23 1488MB DEBUG: Done
16:19:23 1488MB DETAILED: Cache path: C:\Users\MyUser\AppData\Local\Redshift\Cache
16:19:23 1488MB DEBUG: Plugin Cache Location: C:\Users\MyUser\AppData\Local\Redshift\Cache\Textures
16:19:23 1488MB DETAILED: Redshift Initialized
16:19:23 1488MB DETAILED: Version: 3.5.20, Oct 10 2023 13:06:21 [26526a01e]
16:19:23 1488MB DETAILED: Windows Platform (Windows 10 Pro)
16:19:23 1488MB DETAILED: Release Build
16:19:23 1488MB DETAILED: Number of CPU HW threads: 32
16:19:23 1488MB DETAILED: CPU speed: 3.00 GHz
16:19:23 1488MB DETAILED: Total system memory: 63.75 GB
16:19:23 1488MB DETAILED: TDR delay: 60s
16:19:23 1488MB DETAILED: Hardware-accelerated GPU scheduling not enabled
16:19:23 1488MB DETAILED: Driver version: [NVidia] 545.84
16:19:23 1488MB DETAILED: Current working dir: C:\Program Files\Maxon Cinema 4D 2024
16:19:23 1488MB INFO: redshift_LICENSE=<not set>
16:19:23 1489MB DEBUG: RLM License Search Path=C:\ProgramData\Redshift;C:\ProgramData\Maxon\RLM
16:19:23 1489MB DEBUG: License return timeout is disabled (license will be returned on shutdown)
16:19:24 1750MB DETAILED:
16:19:24 1750MB DETAILED: Preparing compute platforms
16:19:24 1750MB DETAILED: Found CUDA compute library in C:\Program Files\Maxon Cinema 4D 2024\plugins\Redshift\res\libs\win64\redshift-core-cuda-vc140.dll
16:19:24 1750MB DETAILED: Could not load the HIP core library from C:\Program Files\Maxon Cinema 4D 2024\plugins\Redshift\res\libs\win64\redshift-core-hip-vc140.dll
16:19:24 1750MB DETAILED: error: The specified module could not be found.
16:19:24 1750MB DETAILED: Found CPU compute library in C:\Program Files\Maxon Cinema 4D 2024\plugins\Redshift\res\libs\win64\redshift-core-cpu-vc140.dll
16:19:24 1750MB DETAILED: Done
16:19:24 1763MB DETAILED: Creating CUDA contexts
16:19:24 1763MB WARNING: Failed to init CUDA (CUDA_ERROR_NO_DEVICE)
16:19:24 1808MB DEBUG: Determining peer-to-peer capability (NVLink or PCIe)
16:19:24 1808MB DEBUG: Done
16:19:24 1929MB DEBUG: PostFX: Initialized
16:19:24 2726MB DEBUG: Redshift RT will run on device NVIDIA GeForce RTX 2070
16:19:24 2751MB DEBUG: Redshift RT shader cache is ON
16:19:24 2751MB DEBUG: Detected 8 performance cores.
16:19:24 2751MB DEBUG: Max workload: 2 shaders, 6 textures, 8 max parallel jobs.
16:19:24 2751MB DEBUG: Plugins: advanced_render analytics archigrass bugslife_client c4d_assetbrowser c4d_bitmapfilter c4d_manager c4d_nodeeditor c4d_nodes c4d_objects c4d_simulation c4d_viewport_render c4d_xtensions ca clothilde dynamics hair interop_bpexchange interop_forger interop_misc interop_moves io_alembic io_cadexchange io_collada14 io_collada15 io_compositing io_dwg io_fbx io_forger io_gltf io_goz io_obj io_skp io_substance io_usd mocca mograph motioncam motiontracker python redshift redshift4c4d sculpt shader sketch sky sla teamrender thinking_particles tool_system_hybrid uvviewport volumes xpressocore
16:19:24 2751MB DEBUG: DrawPort: Vendor: NVIDIA Renderer: NVIDIA GeForce RTX 2070 Version: 12 (545.84)
16:19:24 2752MB DEBUG: PreviewScheduler: Start
