Error: repo.bat package with --name parameter
Trying to package my app using the ./repo.bat package command.
Kit Version is 109.0.1, fresh from the git repository.
Command:
./repo.bat package -n "my_app"
Output:
The redirected argument -n to --image-tag has new behavior. If a value of image_name:version_string is provided, that will be used to build your container. If no colon is detected, your container’s tag will be application_name:the_value_of_this_argument
error: unrecognized arguments: --image-tag my_app
Same also happens with the --name parameter. Documentation suggests that --image-tag is a parameter for the package_container command instead. Seems like some preprocessing is happening here that should only be applied for that command, not for the package command.
Is this a bug, or am I missing something?
Please just use repo.bat package, without the -n and it will package the app directly. There is no need to direct it to the particular kit file.
Found the error in repo.toml:
[[repo.deprecations]]
tool_name = "repo_package"
command = "package"
arg_name = "--name"
arg_redirect_name = "--image-tag"
log_message = "The redirected argument --name to --image-tag has new behavior. If a value of image_name:version_string is provided, that will be used to build your container. If no colon is detected, your container's tag will be application_name:the_value_of_this_argument"
As far as I can tell, tool_name really should be “repo_package_container” and command should be “package_container”.
Changing this makes the “package” command work with the --name parameter again.
I am not trying to direct it to a particular kit file, I am trying to give the package a name.
I see. Ok, well I am glad you found the command. It just zips it up anyway, so you can always just rename the zip file after it packages.
True, but I am running this in a CI/CD pipeline, building 3 separate apps from one repo. I’d either have to add an addititonal step for the renaming or get confused as to which artifact is what. Fixing this deprecation/redirection seems to be the least amount of pain.
I think the confusion stems from the fact that the package_container command apparently used to be just the package command with the --container argument. The intention seems to give developers who were using this a clear way forward to using the new command, but this just broke the regular package command. As of right now, this part of the companion tutorial fails.
Thanks for flagging this. I asked the engineers and they said that the change was mentioned in the changelog.md that ships with the new version.
