Error reported when downloading the program
hello,all:
When downloading the program, Stuck in the system.img file,
The instructions executed are:
sudo ./flash.sh jetson-agx-orin-devkit internal
sudo ./flash.sh p3737-0000+p3701-0000 mmcblk0p1
Both of the above instructions will report errors as: an error was reported in:
error:Return value 8
failed flashing t186ref.
what is the L4T version and the Ubuntu version of your host PC?
What do you get from UART?
L4T vesion:Jestson_Linux_R35.3.1_aarch64
ubuntu version:18.04.1
UART serial port not connected, do you need to connect it?
serial log is sometimes very helpful for debugging, and it may not be sufficient by just looking at the host side flashing log.
It should be easy for AGX Orin, as you just need a micro USB cable.
ok,Let’s operate it here. Connect uart
报错的log:
11:24:24 INFO: Flash Jetson Linux - flash: [ 377.9712 ] […] 100%
11:24:27 INFO: Flash Jetson Linux - flash: [ 377.9796 ] Writing partition B_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 167344 bytes ]
11:24:27 INFO: Flash Jetson Linux - flash: [ 380.3280 ] […] 100%
11:24:29 INFO: Flash Jetson Linux - flash: [ 380.3362 ] Writing partition B_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 119104 bytes ]
11:24:29 INFO: Flash Jetson Linux - flash: [ 382.3962 ] […] 100%
11:24:30 INFO: Flash Jetson Linux - flash: [ 382.4028 ] Writing partition B_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122784 bytes ]
11:24:30 INFO: Flash Jetson Linux - flash: [ 383.8729 ] […] 100%
11:24:32 INFO: Flash Jetson Linux - flash: [ 383.8790 ] Writing partition B_cpu-bootloader with uefi_jetson_with_dtb_sigheader.bin.encrypt [ 3330112 bytes ]
11:25:10 INFO: Flash Jetson Linux - flash: [ 385.3923 ] [… ] 031% [ 385.3923 ] [… ] 062% [ 385.3923 ] [… ] 094% [ 385.3923 ] […] 100%
11:25:13 INFO: Flash Jetson Linux - flash: [ 424.0944 ] Writing partition B_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1064752 bytes ]
11:25:25 INFO: Flash Jetson Linux - flash: [ 426.3667 ] […] 098% [ 426.3667 ] […] 100%
11:25:26 INFO: Flash Jetson Linux - flash: [ 439.2669 ] Writing partition B_eks with eks_t234_sigheader.img.encrypt [ 9232 bytes ]
11:25:26 INFO: Flash Jetson Linux - flash: [ 439.4737 ] […] 100%
11:25:26 INFO: Flash Jetson Linux - flash: [ 439.4767 ] Writing partition B_dce-fw with display-t234-dce_with_kernel_tegra234-p3701-0004-p3737-0000_aligned_blob_w_bin_sigheader.bin.encrypt [ 754128 bytes ]
11:25:26 INFO: Flash Jetson Linux - flash: [ 439.6026 ] […] 100%
11:25:35 INFO: Flash Jetson Linux - flash: [ 439.6296 ] Writing partition B_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
11:25:35 INFO: Flash Jetson Linux - flash: [ 448.8845 ] […] 100%
11:25:38 INFO: Flash Jetson Linux - flash: [ 448.8973 ] Writing partition B_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 537952 bytes ]
11:25:38 INFO: Flash Jetson Linux - flash: [ 452.2161 ] […] 100%
11:25:45 INFO: Flash Jetson Linux - flash: [ 452.2354 ] Writing partition B_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 400960 bytes ]
11:25:45 INFO: Flash Jetson Linux - flash: [ 458.8415 ] […] 100%
11:25:50 INFO: Flash Jetson Linux - flash: [ 458.8607 ] Writing partition B_VER with qspi_bootblob_ver.txt [ 109 bytes ]
11:25:50 INFO: Flash Jetson Linux - flash: [ 463.7894 ] […] 100%
11:25:50 INFO: Flash Jetson Linux - flash: [ 463.8170 ] Writing partition A_VER with qspi_bootblob_ver.txt [ 109 bytes ]
11:25:50 INFO: Flash Jetson Linux - flash: [ 463.8268 ] […] 100%
11:25:50 INFO: Flash Jetson Linux - flash: [ 463.8296 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
11:25:50 INFO: Flash Jetson Linux - flash: [ 463.8389 ] […] 100%
11:25:50 INFO: Flash Jetson Linux - flash: [ 463.8419 ] Writing partition A_kernel with boot.img [ 43065344 bytes ]
11:25:52 INFO: Flash Jetson Linux - flash: [ 463.8476 ] [. ] 002% [ 463.8476 ] [… ] 004% [ 463.8476 ] [… ] 007% [ 463.8476 ] [… ] 009% [ 463.8476 ] [… ] 012% [ 463.8476 ] [… ] 014% [ 463.8476 ] [… ] 017% [ 463.8476 ] [… ] 019% [ 463.8476 ] [… ] 021% [ 463.8476 ] [… ] 024% [ 463.8476 ] [… ] 026% [ 463.8476 ] [… ] 029% [ 463.8476 ] [… ] 031% [ 463.8476 ] [… ] 034% [ 463.8476 ] [… ] 036% [ 463.8476 ] [… ] 038% [ 463.8476 ] [… ] 041% [ 463.8476 ] [… ] 043% [ 463.8476 ] [… ] 046% [ 463.8476 ] [… ] 048% [ 463.8476 ] [… ] 051% [ 463.8476 ] [… ] 053% [ 463.8476 ] [… ] 056% [ 463.8476 ] [… ] 058% [ 463.8476 ] [… ] 060% [ 463.8476 ] [… ] 063% [ 463.8476 ] [… ] 065% [ 463.8476 ] [… ] 068% [ 463.8476 ] [… ] 070% [ 463.8476 ] [… ] 073% [ 463.8476 ] [… ] 075% [ 463.8476 ] [… ] 077% [ 463.8476 ] [… ] 080% [ 463.8476 ] [… ] 082% [ 463.8476 ] [… ] 085% [ 463.8476 ] [… ] 087% [ 463.8476 ] [… ] 090% [ 463.8476 ] [… ] 092% [ 463.8476 ] [… ] 094% [ 463.8476 ] […] 097% [ 463.8476 ] […] 099% [ 463.8476 ] […] 100%
11:25:52 INFO: Flash Jetson Linux - flash: [ 465.5308 ] Writing partition A_kernel-dtb with kernel_tegra234-p3701-0004-p3737-0000.dtb [ 420839 bytes ]
11:25:52 INFO: Flash Jetson Linux - flash: [ 465.5322 ] […] 100%
11:25:52 INFO: Flash Jetson Linux - flash: [ 465.5502 ] Writing partition B_kernel with boot.img [ 43065344 bytes ]
11:25:54 INFO: Flash Jetson Linux - flash: [ 465.5552 ] [. ] 002% [ 465.5552 ] [… ] 004% [ 465.5552 ] [… ] 007% [ 465.5552 ] [… ] 009% [ 465.5552 ] [… ] 012% [ 465.5552 ] [… ] 014% [ 465.5552 ] [… ] 017% [ 465.5552 ] [… ] 019% [ 465.5552 ] [… ] 021% [ 465.5552 ] [… ] 024% [ 465.5552 ] [… ] 026% [ 465.5552 ] [… ] 029% [ 465.5552 ] [… ] 031% [ 465.5552 ] [… ] 034% [ 465.5552 ] [… ] 036% [ 465.5552 ] [… ] 038% [ 465.5552 ] [… ] 041% [ 465.5552 ] [… ] 043% [ 465.5552 ] [… ] 046% [ 465.5552 ] [… ] 048% [ 465.5552 ] [… ] 051% [ 465.5552 ] [… ] 053% [ 465.5552 ] [… ] 056% [ 465.5552 ] [… ] 058% [ 465.5552 ] [… ] 060% [ 465.5552 ] [… ] 063% [ 465.5552 ] [… ] 065% [ 465.5552 ] [… ] 068% [ 465.5552 ] [… ] 070% [ 465.5552 ] [… ] 073% [ 465.5552 ] [… ] 075% [ 465.5552 ] [… ] 077% [ 465.5552 ] [… ] 080% [ 465.5552 ] [… ] 082% [ 465.5552 ] [… ] 085% [ 465.5552 ] [… ] 087% [ 465.5552 ] [… ] 090% [ 465.5552 ] [… ] 092% [ 465.5552 ] [… ] 094% [ 465.5552 ] […] 097% [ 465.5552 ] […] 099% [ 465.5552 ] […] 100%
11:25:54 INFO: Flash Jetson Linux - flash: [ 467.2847 ] Writing partition B_kernel-dtb with kernel_tegra234-p3701-0004-p3737-0000.dtb [ 420839 bytes ]
11:25:54 INFO: Flash Jetson Linux - flash: [ 467.2871 ] […] 100%
11:25:54 INFO: Flash Jetson Linux - flash: [ 467.3041 ] Writing partition recovery with recovery.img [ 46710784 bytes ]
11:25:55 INFO: Flash Jetson Linux - flash: [ 467.3081 ] [. ] 002% [ 467.3081 ] [… ] 004% [ 467.3081 ] [… ] 006% [ 467.3081 ] [… ] 008% [ 467.3081 ] [… ] 011% [ 467.3081 ] [… ] 013% [ 467.3081 ] [… ] 015% [ 467.3081 ] [… ] 017% [ 467.3081 ] [… ] 020% [ 467.3081 ] [… ] 022% [ 467.3081 ] [… ] 024% [ 467.3081 ] [… ] 026% [ 467.3081 ] [… ] 029% [ 467.3081 ] [… ] 031% [ 467.3081 ] [… ] 033% [ 467.3081 ] [… ] 035% [ 467.3081 ] [… ] 038% [ 467.3081 ] [… ] 040% [ 467.3081 ] [… ] 042% [ 467.3081 ] [… ] 044% [ 467.3081 ] [… ] 047% [ 467.3081 ] [… ] 049% [ 467.3081 ] [… ] 051% [ 467.3081 ] [… ] 053% [ 467.3081 ] [… ] 056% [ 467.3081 ] [… ] 058% [ 467.3081 ] [… ] 060% [ 467.3081 ] [… ] 062% [ 467.3081 ] [… ] 065% [ 467.3081 ] [… ] 067% [ 467.3081 ] [… ] 069% [ 467.3081 ] [… ] 071% [ 467.3081 ] [… ] 074% [ 467.3081 ] [… ] 076% [ 467.3081 ] [… ] 078% [ 467.3081 ] [… ] 080% [ 467.3081 ] [… ] 083% [ 467.3081 ] [… ] 085% [ 467.3081 ] [… ] 087% [ 467.3081 ] [… ] 089% [ 467.3081 ] [… ] 092% [ 467.3081 ] [… ] 094% [ 467.3081 ] […] 096% [ 467.3081 ] […] 098% [ 467.3081 ] […] 100%
11:25:55 INFO: Flash Jetson Linux - flash: [ 469.2313 ] Writing partition recovery-dtb with tegra234-p3701-0004-p3737-0000.dtb.rec [ 420839 bytes ]
11:25:56 INFO: Flash Jetson Linux - flash: [ 469.2340 ] […] 100%
11:25:56 INFO: Flash Jetson Linux - flash: [ 469.2847 ] Writing partition esp with esp.img [ 67108864 bytes ]
11:25:58 INFO: Flash Jetson Linux - flash: [ 469.2887 ] 001% [ 469.2887 ] [. ] 003% [ 469.2887 ] [… ] 004% [ 469.2887 ] [… ] 006% [ 469.2887 ] [… ] 007% [ 469.2887 ] [… ] 009% [ 469.2887 ] [… ] 010% [ 469.2887 ] [… ] 012% [ 469.2887 ] [… ] 014% [ 469.2887 ] [… ] 015% [ 469.2887 ] [… ] 017% [ 469.2887 ] [… ] 018% [ 469.2887 ] [… ] 020% [ 469.2887 ] [… ] 021% [ 469.2887 ] [… ] 023% [ 469.2887 ] [… ] 025% [ 469.2887 ] [… ] 026% [ 469.2887 ] [… ] 028% [ 469.2887 ] [… ] 029% [ 469.2887 ] [… ] 031% [ 469.2887 ] [… ] 032% [ 469.2887 ] [… ] 034% [ 469.2887 ] [… ] 035% [ 469.2887 ] [… ] 037% [ 469.2887 ] [… ] 039% [ 469.2887 ] [… ] 040% [ 469.2887 ] [… ] 042% [ 469.2887 ] [… ] 043% [ 469.2887 ] [… ] 045% [ 469.2887 ] [… ] 046% [ 469.2887 ] [… ] 048% [ 469.2887 ] [… ] 050% [ 469.2887 ] [… ] 051% [ 469.2887 ] [… ] 053% [ 469.2887 ] [… ] 054% [ 469.2887 ] [… ] 056% [ 469.2887 ] [… ] 057% [ 469.2887 ] [… ] 059% [ 469.2887 ] [… ] 060% [ 469.2887 ] [… ] 062% [ 469.2887 ] [… ] 064% [ 469.2887 ] [… ] 065% [ 469.2887 ] [… ] 067% [ 469.2887 ] [… ] 068% [ 469.2887 ] [… ] 070% [ 469.2887 ] [… ] 071% [ 469.2887 ] [… ] 073% [ 469.2887 ] [… ] 075% [ 469.2887 ] [… ] 076% [ 469.2887 ] [… ] 078% [ 469.2887 ] [… ] 079% [ 469.2887 ] [… ] 081% [ 469.2887 ] [… ] 082% [ 469.2887 ] [… ] 084% [ 469.2887 ] [… ] 085% [ 469.2887 ] [… ] 087% [ 469.2887 ] [… ] 089% [ 469.2887 ] [… ] 090% [ 469.2887 ] [… ] 092% [ 469.2887 ] [… ] 093% [ 469.2887 ] [… ] 095% [ 469.2887 ] […] 096% [ 469.2887 ] […] 098% [ 469.2887 ] […] 100%
11:25:58 INFO: Flash Jetson Linux - flash: [ 471.9030 ] Writing partition APP with system.img [ 5741762804 bytes ]
11:28:23 INFO: Flash Jetson Linux - flash: [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 000% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] 001% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 002% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [. ] 003% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 004% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 005% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 006% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 007% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 008% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009% [ 471.9095 ] [… ] 009%
11:43:13 INFO: Flash Jetson Linux - flash: Command tegradevflash_v2 --pt flash.xml.bin --create
11:43:13 INFO: Flash Jetson Linux - flash: Failed flashing t186ref.
11:43:13 ERROR: Flash Jetson Linux - flash: *** ERROR: flashing failed.
11:43:13 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
11:43:13 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 30m24s ]
11:43:13 ERROR: Flash Jetson Linux - flash: command terminated with error
11:43:13 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
FLASHING FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
log page:
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2023-06-14_11-06-29.zip (74.6 KB)
你現在給的還是只有host上的flashing log…
但是我們需要的是device上的UART log
你是用NVIDIA官方的DevKit嗎 是的話接上micro USB 然後跑下面這個指令
sudo picocom -b 115200 /dev/ttyACM0
連接開好之後再重燒一次 把UART dump出來的log貼上來
Problem solved:
