Error response from daemon: unauthorized: authentication required
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
I’m trying to install/pull the docker but encountering problem shown below. Can you please help with this?
sudo docker pull nvcr.io/qt5fqij4o1wl/drive-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
:~/temp$ sudo docker pull nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-knext-x86:latest
Please make sure you refer to Install DRIVE OS Linux Docker Containers from NGC | NVIDIA Docs. Thanks.
I’ve followed the instruction suggested by Nvidia, however I still get unauthorized: authentication required shown below. I did signed in and used the Generate API Key feature for the password used below. I’m wondering if my user name needs to be added or given permission by Nvidia.
:~$ sudo docker login nvcr.io
Username: oauthtoken
Password:
Error response from daemon: Get “https://nvcr.io/v2/”: unauthorized: authentication required
Would you be able to tell me what am I doing wrong?
Dear @umit.eroglu,
Can you login to ngc.nvidia.com and confirm if you see docker containers under private registry(Set Up Docker and NVIDIA GPU Cloud Access | NVIDIA Docs)
Yes, here’s the screen capture of the containers
Dear @umit.eroglu,
Please use username as $oauthtoken
Dear @umit.eroglu,
Could you provide any update?
I’m not in the office until next Tuesday, then i can provide the required logs.
