Hello Everyone!
I am trying to install Isaac SDK 2019.3 but its not possible for me I am currently using ubuntu 19.10 because it works better with my hardware but I am not sure if its that (hopefully not!)
This is my hardware:
Lenovo p53:
Xeon E-2276
64 GB Ram
Quadro RTX 5000
and here are the versions of the dependencies that I am using:
emtechiot@emtechiot:~/Isaac$ python3 --version
Python 3.7.5
emtechiot@emtechiot:~/Isaac$ python --version
Python 2.7.17
emtechiot@emtechiot:~/Isaac$ python3 -c ‘import tensorflow as tf; print(tf.version)’
2.0.0
emtechiot@emtechiot:~/Isaac$ python -c ‘import tensorflow as tf; print(tf.version)’
File “”, line 1, in
ImportError: No module named tensorflow
emtechiot@emtechiot:~/Isaac$ bazel version
Build label: 2.0.0
Build target: bazel-out/k8-opt/bin/src/main/java/com/google/devtools/build/lib/bazel/BazelServer_deploy.jar
Build time: Thu Dec 19 12:30:18 2019 (1576758618)
Build timestamp: 1576758618
Build timestamp as int: 1576758618
the first errors that I am getting are this ones (here is a link for the whole list of errors that I am getting ( https://drive.google.com/open?id=16xi43_aKYEfuAFvZUMq9p6r6AYr7uvlI ):
emtechiot@emtechiot:~/Isaac$ sudo bazel build //apps/samples/stereo_dummy
WARNING: /home/emtechiot/Isaac/packages/viewers/BUILD:14:12: in srcs attribute of cc_binary rule //packages/viewers:libviewers_module.so: please do not import ‘//packages_x86_64/viewers:libviewers_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
INFO: Analysed target //apps/samples/stereo_dummy:stereo_dummy (0 packages loaded, 0 targets configured).
INFO: Found 1 target…
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/libjpeg/BUILD.bazel:29:1: Couldn’t build file external/libjpeg/_objs/jpeg/jidctfst.pic.o: undeclared inclusion(s) in rule ‘@libjpeg//:jpeg’:
this rule is missing dependency declarations for the following files included by ‘external/libjpeg/jidctfst.c’:
‘/usr/lib/gcc/x86_64-linux-gnu/9/include/stddef.h’
‘/usr/lib/gcc/x86_64-linux-gnu/9/include/stdarg.h’
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/capnproto/BUILD.bazel:59:1: Couldn’t build file external/capnproto/_objs/kj_heavy/refcount.o: undeclared inclusion(s) in rule ‘@capnproto//:kj_heavy’:
this rule is missing dependency declarations for the following files included by ‘external/capnproto/c++/src/kj/refcount.c++’:
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/capnproto/BUILD.bazel:20:1: Couldn’t build file external/capnproto/_objs/kj_lite/string-tree.pic.o: undeclared inclusion(s) in rule ‘@capnproto//:kj_lite’:
this rule is missing dependency declarations for the following files included by ‘external/capnproto/c++/src/kj/string-tree.c++’:
ERROR: /home/emtechiot/Isaac/engine/core/tensor/BUILD:13:1: Couldn’t build file engine/core/tensor/_objs/element_type/element_type.pic.o: undeclared inclusion(s) in rule ‘//engine/core/tensor:element_type’:
this rule is missing dependency declarations for the following files included by ‘engine/core/tensor/element_type.cpp’:
‘/usr/lib/gcc/x86_64-linux-gnu/9/include/stdint.h’
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/capnproto/BUILD.bazel:20:1: Couldn’t build file external/capnproto/_objs/kj_lite/memory.o: undeclared inclusion(s) in rule ‘@capnproto//:kj_lite’:
this rule is missing dependency declarations for the following files included by ‘external/capnproto/c++/src/kj/memory.c++’:
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/capnproto/BUILD.bazel:20:1: Couldn’t build file external/capnproto/_objs/kj_lite/test-helpers.o: undeclared inclusion(s) in rule ‘@capnproto//:kj_lite’:
this rule is missing dependency declarations for the following files included by ‘external/capnproto/c++/src/kj/test-helpers.c++’:
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/capnproto/BUILD.bazel:59:1: Couldn’t build file external/capnproto/_objs/kj_heavy/string-tree.o: undeclared inclusion(s) in rule ‘@capnproto//:kj_heavy’:
ERROR: /root/.cache/bazel/_bazel_root/2a61a6a4ef36adb8d9f83ad3fb74d7f6/external/capnproto/BUILD.bazel:88:1: Couldn’t build file external/capnproto/_objs/capnp_lite/serialize.o: undeclared inclusion(s) in rule ‘@capnproto//:capnp_lite’:
this rule is missing dependency declarations for the following files included by ‘external/capnproto/c++/src/capnp/serialize.c++’:
Thank you very much for your time!!
