Error running Riva Sample apps Virtual Assistant - Weatherbot
Workstation
Hardware - GPU (GeForce RTX 2070)
Hardware - CPU
Operating System - Win 10
Riva Version 2.14.0
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
In trying to run the riva sample apps → Virtual Assistant
  • Following this tutorial: Riva Virtual Assistant Example — NVIDIA Riva
    – After pulling the ngc registry resource download-version "nvidia/riva/riva_quickstart:x.y.z"
    — I used the 2.14.0 version of riva_quickstart
    – I am unable to find and install the riva-api pip install riva_api-<x.y.z>-py3-none-any.whl
    – i only have nemo2riva-2.14.0-py3-none-any.whl
  • When running main.py i get this error:
    import riva_api.riva_audio_pb2 as ra ModuleNotFoundError: No module named 'riva_api'
I solved this by instead of running the weatherbot i connected throguh the ngc api to the foundation models and got that to work. So now i just need to figure out the last piece of the puzzle.
Text Question → LLM → Text Reply → Riva TTS → Audio 2 Face
