Error running webcam
When I run the example it works fine, but when I want to run it again an error occur.
dlinano@jetson-nano:~/deepstream_sdk_v4.0.2_jetson/sources/apps/dli_apps/deepstream-test1-webcam_in$ ./deepstream-test1-app dstest1_pgie_config.txt
 *** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Now playing: dstest1_pgie_config.txt
Opening in BLOCKING MODE
Creating LL OSD context new
Running...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
(deepstream-test1-app:9087): GLib-GObject-WARNING **: 14:18:08.566: g_object_get_is_valid_property: object class 'GstUDPSrc' has no property named 'pt'
^Z
[1]+  Stopped                 ./deepstream-test1-app dstest1_pgie_config.txt
Running...
ERROR from element camera-source: Device '/dev/video2' is busy
Error details: gstv4l2object.c(3754): gst_v4l2_object_set_format_full (): /GstPipeline:dstest1-pipeline/GstV4l2Src:camera-source:
Call to S_FMT failed for YUYV @ 640x480: Device or resource busy
Returned, stopping playback
Deleting pipeline
We have the sample
deepstream_sdk_v4.0.2_jetson\sources\apps\sample_apps\deepstream-test1
But there is no sample called deepstream-test1-webcam_in
Probably it is something wrong in your customization. Form the log, seems like you don’t close /dev/video2 in intermination
