Hey all,
A couple weeks ago I upgraded to Ubutu 10.04, with CUDA 3.0. I Got FindCUDA.cmake up and running and everything. However, I haven’t done much development in CUDA for several weeks until today. When I try and compile my project with Cmake, or even if I compile a project under the CUDA sdk, I get the following type of erros:
[codebox]nere@red5:~/cuda/current/NVIDIA_GPU_Computing_SDK/C/src/matrixMul$ make
Signal: Illegal instruction in Writing WHIRL file phase.
(0): Error: Signal Illegal instruction in phase Writing WHIRL file – processing aborted
*** Internal stack backtrace:
/home/nere/cuda/current/cuda/open64/lib//gfec() [0x7489af]
/home/nere/cuda/current/cuda/open64/lib//gfec() [0x7495f9]
/home/nere/cuda/current/cuda/open64/lib//gfec(ErrMsgLine+0x8d) [0x748d4d]
/home/nere/cuda/current/cuda/open64/lib//gfec() [0x749f96]
/lib/libc.so.6(+0x33af0) [0x2ba1c385faf0]
/home/nere/cuda/current/cuda/open64/lib//gfec(put_var_into_stack+0) [0x56e500]
/home/nere/cuda/current/cuda/open64/lib//gfec(c_mark_addressable+0x74) [0x511644]
/home/nere/cuda/current/cuda/open64/lib//gfec(build_array_ref+0xa5) [0x515675]
/home/nere/cuda/current/cuda/open64/lib//gfec(yyparse+0x3131) [0x6d48e1]
/home/nere/cuda/current/cuda/open64/lib//gfec(c_common_parse_file+0xf) [0x4ee8cf]
/home/nere/cuda/current/cuda/open64/lib//gfec(compile_file+0x55) [0x6a2c25]
/home/nere/cuda/current/cuda/open64/lib//gfec(main+0x48) [0x4d96b8]
/lib/libc.so.6(__libc_start_main+0xfd) [0x2ba1c384ac4d]
/home/nere/cuda/current/cuda/open64/lib//gfec(calloc+0x23a) [0x455b0a]
make: *** [obj/x86_64/release/matrixMul.cu.o] Error 1
[/codebox]
Never seen this before, and I don’t think I did anything to mess up CUDA, though it is likely I have run updates since moving to Ubuntu 10.04. Any clues?
Andy
