Error starting flasher sidecar process
I’m getting the message error starting sidecar process on balena etcher… What do I do now to set up Jetson orin nano
Hi @onyx10.inc,
That message is from Balena Etcher on your host PC, so first please confirm which setup image you downloaded and which storage device you are writing to.
  1. If you are using the latest JetPack 7.2 setup flow
    Please write the Jetson ISO to a USB flash drive, not directly to the microSD card. The microSD card or NVMe SSD is the installation target after the Jetson boots from the USB installer.
    Official guide:
    Quick Start Guide — Jetson Orin Nano Developer Kit - User Guide
  2. If you are using a JetPack 6.x SD card image
    Please confirm the exact image filename you downloaded. Some Jetson Orin Nano Developer Kits with older factory firmware may also need the QSPI/UEFI firmware update path before booting newer JetPack releases:
    JetPack 6.x Update Path — Jetson Orin Nano Developer Kit - User Guide
Recommendation:
Please share:
  1. Your host PC OS, for example Windows/macOS/Ubuntu
  2. The Balena Etcher version
  3. The exact JetPack image or ISO filename you downloaded
  4. Whether you are writing it to a USB flash drive, microSD card, or NVMe SSD
Then we can point you to the correct setup path.
My host PC is a Asus sonic master/windows
I just downloaded balena from balena.io
I’m trying to write the image to a SanDisk USB drive
Hi @onyx10.inc,
Thanks for confirming. Since you are writing to a SanDisk USB drive, please first check the exact NVIDIA image filename you selected in Balena Etcher.
  1. If the file is a JetPack 7.2 Jetson ISO
    Writing it to the USB drive is the correct flow. Please continue with the USB installer flow in the Quick Start Guide:
  2. If the file is a JetPack 6.x SD card image
    Please do not write that image to the USB drive. The JetPack 6.x SD card image should be written to a microSD card for the Jetson Orin Nano Developer Kit setup/update path:
Recommendation:
Please share the exact image or ISO filename you downloaded. Then we can confirm whether you should continue with the USB installer path or switch to the microSD update/setup path.
