Error stopping the activation of isaac-ros container
I had an isaac-ros installation on Docker that was working fine, but since I was encountering persistent errors with the isaac-ros-cumotion tutorial, I decided to delete my isaac-ros-dev ws to reinstall and rebuild the packages. However, I can no longer restart the container, even after following the entire tutorial again.
arthur@arthur-MS-7E66:~$ isaac-ros activate
/home/arthur/workspaces/isaac_ros-dev
Logged in to nvcr.io/nvidia/isaac/ros. Using this for cache.
['noble', 'ros2_jazzy', 'realsense', 'isaac_manipulation_source']
Error: Could not resolve all Dockerfiles.
Image key: isaac_manipulation_source.noble.realsense.ros2_jazzy
Docker search dirs: ['/etc/isaac-ros-cli/docker', '/home/arthur/workspaces/isaac_ros-dev//docker', '/home/arthur/workspaces/isaac_ros-dev//src/isaac_ros_custom_bringup/isaac_ros_4']
Common config file: /home/arthur/workspaces/isaac_ros-dev//../scripts/.isaac_ros_common-config
$ISAAC_ROS_WS: /home/arthur/workspaces/isaac_ros-dev/
Please ensure that the $ISAAC_ROS_WS variable is set, the .isaac_ros_common-config file is present and valid, and that the docker_search_dirs are present and correct.
Is there a step that I am missing ?
Thanks for your help.
Hello @ar.gounot,
Thanks for posting in the Isaac ROS forum!
From the log you provided, the CLI is complaining that it can’t resolve the image key:
The first thing to confirm is that ISAAC_ROS_WS is correctly set:
echo "$ISAAC_ROS_WS"
ls -la "$ISAAC_ROS_WS"
You should see:
and inside that directory a src/ folder, etc.
If it’s empty or different, set it and reload your shell.
echo 'export ISAAC_ROS_WS=$HOME/workspaces/isaac_ros-dev' >> ~/.bashrc
source ~/.bashrc
Please reference this guide for more information.
As there haven’t been any recent updates on this discussion, we’ll be closing the thread to keep the forum organized.
If you continue to experience this issue or have new questions, please start a new topic and include a reference to this discussion for context. This will help our team and other community members assist you more effectively.
Thank you for your participation in the NVIDIA Isaac ROS community.
