Hello. I have a code, which worked fine with pgc++ 19.10. But now nvc++21.9-0 does not compile it and throws an error:
/data/70-gaa/Desktop/CURRENT_WORK/tpt3_current_work/tpt/include/T3DataHolder.h", line 1597: error: this kind of pragma may not be used here
#pragma acc parallel loop gang vector copy(count01,count23,init,fin) present(particles,ind23)
detected during instantiation of "void DataHolder<Floating>::Compress() [with Floating=t3::FloatingType]" at line 346 of "/data/70-gaa/Desktop/CURRENT_WORK/tpt3_current_work/main.cpp"
Compile on Intel KNL with GPU Titan V installed in it.
The piece of code looks like:
constexpr unsigned int GL=10000000;
constexpr unsigned int Nbin = 8;
constexpr unsigned int BLt = GL/Nbin;
int ind01[Nbin][BLt];
int ind23[Nbin][BLt];
int count01[Nbin];
int count23[Nbin];
int init[Nbin];
int fin[Nbin];
//this is the line #1597:
for(int b=0; b<Nbin; ++b)
for(int i=init[b]; i<fin[b]; ++i)
if(particles[i].ir<2) ind23[b][count01[b]--]=i;
else ind23[b][count23[b]++]=i;
particles - array of structures.
Please, be so kind to help me fix this issue.
I’m not sure why it worked before, but the “loop” directive needs to be placed just before a for loop. Hence you’ll want to remove the extra “{ }” or move the “loop” directive inside of the “{”.
Thank You very much for the answer.
I also have a code snippet:
#include "T3Inelasticdd_DB.hh"
struct Particle{
double m[16];
constexpr unsigned int GL=5000000;
Particle particles[GL];
Particle arr1[GL];
Particle arr2[GL];
Particle arr3[GL];
double csBorderDataFS[GL];
long int MAX_ELEMENT;
unsigned int SHIFT;
int Ntop=0;
long int INJECTED_PARTICLES=0;
int LIFE=0;
constexpr int SKA_BINS_NUMBER=1000;
double SKA_Tls[SKA_BINS_NUMBER];
int main(int argc, char **argv)
#ifdef OPENACC
#pragma acc data create(ind01,ind23,arr1,arr2,arr3,csBorderDataFS) \
copyin(particles) \
copy(SKA_Tls[0:SKA_BINS_NUMBER])
#endif
[7%] Linking CXX executable Test
CMakeFiles/Test.dir/main.cpp.o: in function `__sti___51__data_70_gaa_Desktop_CURRENT_WORK_MinRepEx_main_cpp_Ntop':
nvc++3wfeL30c9dld.ll:(.text+0x913): relocation truncated to fit: R_X86_64_PC32 against symbol `__I___51__data_70_gaa_Desktop_CURRENT_WORK_MinRepEx_main_cpp_Ntop' defined in .bss section in CMakeFiles/Test.dir/main.cpp.o
nvc++3wfeL30c9dld.ll:(.text+0x91e): relocation truncated to fit: R_X86_64_PC32 against symbol `__I___51__data_70_gaa_Desktop_CURRENT_WORK_MinRepEx_main_cpp_Ntop' defined in .bss section in CMakeFiles/Test.dir/main.cpp.o
pgacclnk: child process exit status 1: /usr/bin/ld
make[2]: *** [CMakeFiles/Test.dir/build.make:513: Test] Error 2
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/Test.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
You see, I don’t use T3Inelasticdd_DB.hh in this code snippet. If to comment #include, the code compiles. The code also compiles if only to set:
constexpr unsigned int GL=1000000;
I understand I don’t provide You the code of T3Inelasticdd_DB.hh, but, can’t You guess, please, what may cause such an error?
Is there a pggdecode in nvc++ to decode __I___51__data_70_gaa_Desktop_CURRENT_WORK_MinRepEx_main_cpp_Ntop?
I don’t know the size of “Particle” but assume these arrays are going over the 2GB limit set by the Small memory model (default). Try adding the flag “-mcmodel=medium” which switches to the Medium memory model allowing for static objects greater than 2GB.
