Hi, This is the error I’m getting since yesterday.
I don’t know why, I haven’t added or removed anything before this came.
Please also dump the serial console log. Do you always hit this even after reboot?
Can I get serial log just by connecting with my usb. I don’t have jumper wires to connect to gpio now
Are you using NX devkit as carrier board? If yes, there is a micro usb port on your devkit but it is actually a uart port.
This is the Xavier. It’s a kit…
Which side micro usb? The usb type c port in the front side or the back side along with Ethernet and hdmi port?
Note that Xavier dev kits have a 40 pin header, and that if you look at that connector, the micro-USB is on the left, and the USB-C is on the right.
