error to run trtexe onnx file
Here is log:
WARNING: ONNX model has a newer ir_version (0.0.6) than this parser was built against (0.0.3).
While parsing node number 1 [Div]:
ERROR: ModelImporter.cpp:296 In function importModel:
[5] Assertion failed: tensors.count(input_name)
[01/10/2020-15:13:34] [E] Failed to parse onnx file
[01/10/2020-15:13:34] [E] Parsing model failed
[01/10/2020-15:13:34] [E] Engine creation failed
[01/10/2020-15:13:34] [E] Engine set up failed
This error indicates that your model cannot be imported.
A common cause is that your model is somehow not supported by our onnx parser.
Could you check if your model is full-supported by our parser from the supported matrix first?
https://docs.nvidia.com/deeplearning/sdk/tensorrt-support-matrix/index.html#supported-ops
