I want to try TensorRT Inference server samples in deepstream5.0 sdk, and i followed the instructions in READMEof the deepstream sdk. I run the sample by that commend deepstream-app -c source1_primary_classifier.txt , which the txt file located in this address /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app-trtis. Hiowever I get that error:
2020-06-03 10:12:35.796329: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
** Using winsys: x11 **
** 0:00:03.486556065 16412 0x2e087760 WARN nvinferserver gstnvinferserver_impl.cpp:248:validatePluginConfig:<primary_gie> warning: Configuration file unique-id reset to: 1**
** I0603 02:12:37.069223 16412 server.cc:120] Initializing Triton Inference Server**
** E0603 02:12:37.250638 16412 model_repository_manager.cc:1519] instance group inception_graphdef_0 of model inception_graphdef specifies invalid or unsupported gpu id of 0. The minimum required CUDA compute compatibility is 6.000000**
** ERROR: TRTIS: failed to load model inception_graphdef, trtis_err_str:INTERNAL, err_msg:failed to load 'inception_graphdef', no version is available**
** ERROR: failed to load model: inception_graphdef, nvinfer error:NVDSINFER_TRTIS_ERROR**
** ERROR: failed to initialize backend while ensuring model:inception_graphdef ready, nvinfer error:NVDSINFER_TRTIS_ERROR**
** 0:00:03.669802890 16412 0x2e087760 ERROR nvinferserver gstnvinferserver.cpp:362:gst_nvinfer_server_logger:<primary_gie> nvinferserver[UID 1]: Error in createNNBackend() <infer_trtis_context.cpp:199> [UID = 1]: failed to initialize trtis backend for model:inception_graphdef, nvinfer error:NVDSINFER_TRTIS_ERROR**
** I0603 02:12:37.251076 16412 server.cc:179] Waiting for in-flight inferences to complete.**
** I0603 02:12:37.251111 16412 server.cc:194] Timeout 30: Found 0 live models and 0 in-flight requests**
** 0:00:03.669925653 16412 0x2e087760 ERROR nvinferserver gstnvinferserver.cpp:362:gst_nvinfer_server_logger:<primary_gie> nvinferserver[UID 1]: Error in initialize() <infer_base_context.cpp:78> [UID = 1]: create nn-backend failed, check config file settings, nvinfer error:NVDSINFER_TRTIS_ERROR**
** 0:00:03.669955862 16412 0x2e087760 WARN nvinferserver gstnvinferserver_impl.cpp:439:start:<primary_gie> error: Failed to initialize InferTrtIsContext**
** 0:00:03.669975185 16412 0x2e087760 WARN nvinferserver gstnvinferserver_impl.cpp:439:start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app-trtis/config_infer_primary_classifier_inception_graphdef_postprocessInTrtis.txt**
** 0:00:03.670062426 16412 0x2e087760 WARN nvinferserver gstnvinferserver.cpp:460:gst_nvinfer_server_start:<primary_gie> error: gstnvinferserver_impl start failed**
** ** ERROR: <main:651>: Failed to set pipeline to PAUSED**
** Quitting**
** ERROR from primary_gie: Failed to initialize InferTrtIsContext**
** Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.cpp(439): start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie:**
** Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app-trtis/config_infer_primary_classifier_inception_graphdef_postprocessInTrtis.txt**
** ERROR from primary_gie: gstnvinferserver_impl start failed**
** Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinferserver/gstnvinferserver.cpp(460): gst_nvinfer_server_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie**
** App run failed**
