Error trying to connect with streaming client
I have installed Omniverse on my laptop with Linux 20.04.1 and i’m trying to connect to a workstation (also with Linux 20.04.1) via wireless. I successfully connected through terminal, I have installed the streaming client, i inserted the IP of my server, but, when i try to connect i get the following error.
An unknown error occured (0x7F00)
Thank you for the help
Can you explain what you are trying to do. Are you trying to stream an omniverse app from one machine to another in a read only window ?
Hi Richard, thank you the answer. I apologize but i solved the problem because i installed the wrong version of streaming client instead of the workstation installation
Great thanks
