I trained FaceNet caffe model on DIGIT. The classification works there. However, I failed to deploy to DeepStream.
Here’s the callstack:
Creating LL OSD context new
0:00:02.507183963 25464 0x7f40002390 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
Weights for layer block35_1/Scale doesn't exist
0:00:03.656227753 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block35_2/Scale doesn't exist
0:00:03.658541197 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block35_3/Scale doesn't exist
0:00:03.661110013 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block35_4/Scale doesn't exist
0:00:03.663601380 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block35_5/Scale doesn't exist
0:00:03.666072538 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_1/Scale doesn't exist
0:00:03.719697779 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_2/Scale doesn't exist
0:00:03.735173960 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_3/Scale doesn't exist
0:00:03.751555061 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_4/Scale doesn't exist
0:00:03.768300650 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_5/Scale doesn't exist
0:00:03.783780894 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_6/Scale doesn't exist
0:00:03.800753885 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_7/Scale doesn't exist
0:00:03.816613931 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_8/Scale doesn't exist
0:00:03.833887971 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_9/Scale doesn't exist
0:00:03.850282770 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block17_10/Scale doesn't exist
0:00:03.867608426 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block8_1/Scale doesn't exist
0:00:04.036783473 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block8_2/Scale doesn't exist
0:00:04.072508493 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block8_3/Scale doesn't exist
0:00:04.108916970 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block8_4/Scale doesn't exist
0:00:04.145886869 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer block8_5/Scale doesn't exist
0:00:04.183114067 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Weights for layer Block8/Scale doesn't exist
0:00:04.220014641 25464 0x7f40002390 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): CaffeParser: ERROR: Attempting to access NULL weights
Here’s my deploy.prototxt:
input: "data"
input_shape {
dim: 1
dim: 3
dim: 160
dim: 160
layer {
type: "Convolution"
bottom: "data"
top: "Conv2d_1a_3x3"
convolution_param {
num_output: 32
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
bottom: "Conv2d_1a_3x3"
batch_norm_param {
use_global_stats: true
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Conv2d_2a_3x3"
convolution_param {
num_output: 32
pad: 0
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "Conv2d_2a_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Conv2d_2b_3x3"
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "Conv2d_2b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Pooling"
top: "MaxPool_3a_3x3"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "MaxPool_3a_3x3"
top: "Conv2d_3b_1x1"
convolution_param {
num_output: 80
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "Conv2d_3b_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Conv2d_4a_3x3"
convolution_param {
num_output: 192
pad: 0
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "Conv2d_4a_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Conv2d_4b_3x3"
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
bottom: "Conv2d_4b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_1/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_1/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_1/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_1/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_1/Branch_1/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_1/Branch_1/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_1/Branch_2/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_1/Branch_2/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_1/Branch_2/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_1/Branch_2/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_1/Branch_2/Conv2d_0c_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_1/Branch_2/Conv2d_0c_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block35_1/Concat"
layer {
type: "Convolution"
bottom: "block35_1/Concat"
top: "block35_1/Conv2d_1x1"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block35_1/Conv2d_1x1"
top: "block35_1/Scale"
scale_param {
filler {
value: 0.170000001788
layer {
type: "Eltwise"
bottom: "block35_1/Scale"
top: "block35_1/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block35_1/Sum"
layer {
type: "Convolution"
top: "block35_2/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_2/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_2/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_2/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_2/Branch_1/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_2/Branch_1/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_2/Branch_2/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_2/Branch_2/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_2/Branch_2/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_2/Branch_2/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_2/Branch_2/Conv2d_0c_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_2/Branch_2/Conv2d_0c_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block35_2/Concat"
layer {
type: "Convolution"
bottom: "block35_2/Concat"
top: "block35_2/Conv2d_1x1"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block35_2/Conv2d_1x1"
top: "block35_2/Scale"
scale_param {
filler {
layer {
type: "Eltwise"
bottom: "block35_2/Scale"
top: "block35_2/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block35_2/Sum"
layer {
type: "Convolution"
top: "block35_3/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_3/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_3/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_3/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_3/Branch_1/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_3/Branch_1/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_3/Branch_2/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_3/Branch_2/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_3/Branch_2/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_3/Branch_2/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_3/Branch_2/Conv2d_0c_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_3/Branch_2/Conv2d_0c_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block35_3/Concat"
layer {
type: "Convolution"
bottom: "block35_3/Concat"
top: "block35_3/Conv2d_1x1"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block35_3/Conv2d_1x1"
top: "block35_3/Scale"
scale_param {
filler {
layer {
type: "Eltwise"
bottom: "block35_3/Scale"
top: "block35_3/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block35_3/Sum"
layer {
type: "Convolution"
top: "block35_4/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_4/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_4/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_4/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_4/Branch_1/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_4/Branch_1/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_4/Branch_2/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_4/Branch_2/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_4/Branch_2/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_4/Branch_2/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_4/Branch_2/Conv2d_0c_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_4/Branch_2/Conv2d_0c_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block35_4/Concat"
layer {
type: "Convolution"
bottom: "block35_4/Concat"
top: "block35_4/Conv2d_1x1"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block35_4/Conv2d_1x1"
top: "block35_4/Scale"
scale_param {
filler {
layer {
type: "Eltwise"
bottom: "block35_4/Scale"
top: "block35_4/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block35_4/Sum"
layer {
type: "Convolution"
top: "block35_5/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_5/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_5/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_5/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_5/Branch_1/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_5/Branch_1/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_5/Branch_2/Conv2d_0a_1x1"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_5/Branch_2/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_5/Branch_2/Conv2d_0b_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_5/Branch_2/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block35_5/Branch_2/Conv2d_0c_3x3"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "block35_5/Branch_2/Conv2d_0c_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block35_5/Concat"
layer {
type: "Convolution"
bottom: "block35_5/Concat"
top: "block35_5/Conv2d_1x1"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block35_5/Conv2d_1x1"
top: "block35_5/Scale"
scale_param {
filler {
layer {
type: "Eltwise"
bottom: "block35_5/Scale"
top: "block35_5/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block35_5/Sum"
layer {
type: "Convolution"
top: "Mixed_6a/Branch_0/Conv2d_1a_3x3"
convolution_param {
num_output: 384
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
bottom: "Mixed_6a/Branch_0/Conv2d_1a_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Mixed_6a/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 192
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "Mixed_6a/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Mixed_6a/Branch_1/Conv2d_0b_3x3"
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
bottom: "Mixed_6a/Branch_1/Conv2d_0b_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Mixed_6a/Branch_1/Conv2d_1a_3x3"
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
bottom: "Mixed_6a/Branch_1/Conv2d_1a_3x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Pooling"
top: "MaxPool_1a_3x3"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
pad: 0
layer {
type: "Concat"
bottom: "MaxPool_1a_3x3"
top: "Mixed_6a/Concat"
layer {
type: "Convolution"
bottom: "Mixed_6a/Concat"
top: "block17_1/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block17_1/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_1/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block17_1/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_1/Branch_1/Conv2d_0b_1x7"
convolution_param {
num_output: 128
stride: 1
pad_h: 0
pad_w: 3
kernel_h: 1
kernel_w: 7
layer {
type: "BatchNorm"
bottom: "block17_1/Branch_1/Conv2d_0b_1x7"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_1/Branch_1/Conv2d_0c_7x1"
convolution_param {
num_output: 128
stride: 1
pad_h: 3
pad_w: 0
kernel_h: 7
kernel_w: 1
layer {
type: "BatchNorm"
bottom: "block17_1/Branch_1/Conv2d_0c_7x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block17_1/Concat"
layer {
type: "Convolution"
bottom: "block17_1/Concat"
top: "block17_1/Conv2d_1x1"
convolution_param {
num_output: 896
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block17_1/Conv2d_1x1"
top: "block17_1/Scale"
scale_param {
filler {
value: 0.10000000149
layer {
type: "Eltwise"
bottom: "block17_1/Scale"
top: "block17_1/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block17_1/Sum"
layer {
type: "Convolution"
top: "block17_2/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block17_2/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_2/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block17_2/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_2/Branch_1/Conv2d_0b_1x7"
convolution_param {
num_output: 128
stride: 1
pad_h: 0
pad_w: 3
kernel_h: 1
kernel_w: 7
layer {
type: "BatchNorm"
bottom: "block17_2/Branch_1/Conv2d_0b_1x7"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_2/Branch_1/Conv2d_0c_7x1"
convolution_param {
num_output: 128
stride: 1
pad_h: 3
pad_w: 0
kernel_h: 7
kernel_w: 1
layer {
type: "BatchNorm"
bottom: "block17_2/Branch_1/Conv2d_0c_7x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "block17_2/Concat"
layer {
type: "Convolution"
bottom: "block17_2/Concat"
top: "block17_2/Conv2d_1x1"
convolution_param {
num_output: 896
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "block17_2/Conv2d_1x1"
top: "block17_2/Scale"
scale_param {
filler {
layer {
type: "Eltwise"
bottom: "block17_2/Scale"
top: "block17_2/Sum"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
bottom: "block17_2/Sum"
layer {
type: "Convolution"
bottom: "Block8/Concat"
top: "Block8/Conv2d_1x1"
convolution_param {
num_output: 1792
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
bottom: "Block8/Conv2d_1x1"
top: "Block8/Scale"
scale_param {
filler {
value: 1.0
layer {
type: "Eltwise"
bottom: "Block8/Scale"
bottom: "block8_5/Sum"
top: "Block8/Sum"
eltwise_param {
operation: SUM
layer {
type: "Pooling"
bottom: "Block8/Sum"
top: "AvgPool_1a_8x8"
pooling_param {
pool: AVE
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "AvgPool_1a_8x8"
top: "Conv1x1_512"
convolution_param {
num_output: 512
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "Conv1x1_512"
top: "Bottleneck"
batch_norm_param {
layer {
type: "Scale"
bottom: "Bottleneck"
top: "Bottleneck"
scale_param {
bias_term: true
layer {
type: "Flatten"
top: "flatten"
layer {
type: "Softmax"
bottom: "flatten"
top: "softmax"
Would it be to much trouble to post youre train_val.prototxt produced by digits.
I would like to compare it to these:
https://github.com/valdivj/ds_resnet10
layer {
type: "Data"
top: "data"
top: "label"
include {
phase: TRAIN
transform_param {
mean_file: "/workspace/jobs/20191209-200210-86e9/mean.binaryproto"
data_param {
source: "/workspace/jobs/20191209-200210-86e9/train_db"
batch_size: 16
backend: LMDB
layer {
type: "Convolution"
bottom: "data"
convolution_param {
num_output: 32
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
convolution_param {
num_output: 80
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 192
pad: 0
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 384
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 192
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 2
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
pad: 0
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
stride: 1
pad_h: 0
pad_w: 3
kernel_h: 1
kernel_w: 7
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
stride: 1
pad_h: 3
pad_w: 0
kernel_h: 7
kernel_w: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 896
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
stride: 1
pad_h: 0
pad_w: 3
kernel_h: 1
kernel_w: 7
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
convolution_param {
num_output: 128
stride: 1
pad_h: 3
pad_w: 0
kernel_h: 7
kernel_w: 1
layer {
type: "BatchNorm"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 896
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
scale_param {
filler {
layer {
type: "Eltwise"
eltwise_param {
operation: SUM
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_3/Branch_0/Conv2d_1x1"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block17_3/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_3/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "block17_3/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "block17_3/Branch_1/Conv2d_0b_1x7"
convolution_param {
num_output: 128
stride: 1
pad_h: 0
pad_w: 3
kernel_h: 1
kernel_w: 7
layer {
type: "BatchNorm"
bottom: "block17_3/Branch_1/Conv2d_0b_1x7"
batch_norm_param {
layer {
type: "BatchNorm"
bottom: "Block8/Branch_0/Conv2d_1x1"
top: "Block8/Branch_0/Conv2d_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Block8/Branch_1/Conv2d_0a_1x1"
convolution_param {
num_output: 192
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
bottom: "Block8/Branch_1/Conv2d_0a_1x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Block8/Branch_1/Conv2d_0b_1x3"
convolution_param {
num_output: 192
stride: 1
pad_h: 0
pad_w: 1
kernel_h: 1
kernel_w: 3
layer {
type: "BatchNorm"
bottom: "Block8/Branch_1/Conv2d_0b_1x3"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "Block8/Branch_1/Conv2d_0c_3x1"
convolution_param {
num_output: 192
stride: 1
pad_h: 1
pad_w: 0
kernel_h: 3
kernel_w: 1
layer {
type: "BatchNorm"
bottom: "Block8/Branch_1/Conv2d_0c_3x1"
batch_norm_param {
layer {
type: "Scale"
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Concat"
top: "Block8/Concat"
layer {
type: "Convolution"
convolution_param {
num_output: 1792
pad: 0
kernel_size: 1
stride: 1
layer {
type: "Scale"
top: "Block8/Scale"
scale_param {
filler {
value: 1.0
layer {
type: "Eltwise"
top: "Block8/Sum"
eltwise_param {
operation: SUM
layer {
type: "Pooling"
pooling_param {
pool: AVE
kernel_size: 3
stride: 2
layer {
type: "Convolution"
top: "Conv1x1_512"
convolution_param {
num_output: 512
pad: 0
kernel_size: 1
stride: 1
layer {
type: "BatchNorm"
top: "Bottleneck"
batch_norm_param {
layer {
type: "Scale"
top: "Bottleneck"
scale_param {
bias_term: true
layer {
type: "Flatten"
top: "flatten"
layer {
type: "Accuracy"
bottom: "flatten"
bottom: "label"
top: "accuracy"
include {
phase: TEST
layer {
type: "SoftmaxWithLoss"
bottom: "flatten"
bottom: "label"
top: "loss"
You can deploy it by tensorRT firstly. Do you mind provide your caffe model?
Here’s the model downloaded from DIGIT
https://www.dropbox.com/sh/5m3muojw9n8hlyw/AACwDPE1iEnlnI59fjGl7Lk2a?dl=0
FYI, I tested model in docker nvcaffe 19.10-py2 and it worked.
deploy prototxt has problem. You can use trtexec to check.
$ ./trtexec --deploy=/home/cding/tmp/1068181_caffe_prototxt.txt --output=softmax
[I] deploy: /home/cding/tmp/1068181_caffe_prototxt.txt
[I] output: softmax
[libprotobuf ERROR google/protobuf/text_format.cc:298] Error parsing text-format ditcaffe.NetParameter: 2102:1: Expected identifier, got: .
[E] [TRT] CaffeParser: Could not parse deploy file
[E] Engine could not be created
&&&& FAILED TensorRT.trtexec # ./trtexec_debug --deploy=/home/cding/tmp/1068181_caffe_prototxt.txt --output=softmax
./trtexec --deploy=./TensorRT-5.1.5.0/data/mnist/deploy.prototxt --output=prob
[I] deploy: /home/cding/tensorrt/TensorRT-5.1.5.0/data/mnist/deploy.prototxt
[I] output: prob
[I] Input "data": 1x28x28
[I] Output "prob": 10x1x1
[W] [TRT] TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 9.0.10. This mismatch may potentially cause undefined behavior.
[I] Average over 10 runs is 0.227462 ms (host walltime is 0.308038 ms, 99% percentile time is 0.265152).
[I] Average over 10 runs is 0.233622 ms (host walltime is 0.317284 ms, 99% percentile time is 0.29696).
[I] Average over 10 runs is 0.22392 ms (host walltime is 0.303886 ms, 99% percentile time is 0.23632).
[I] Average over 10 runs is 0.224538 ms (host walltime is 0.30449 ms, 99% percentile time is 0.239616).
[I] Average over 10 runs is 0.222973 ms (host walltime is 0.303562 ms, 99% percentile time is 0.241664).
[I] Average over 10 runs is 0.229222 ms (host walltime is 0.311122 ms, 99% percentile time is 0.240416).
[I] Average over 10 runs is 0.225843 ms (host walltime is 0.308948 ms, 99% percentile time is 0.236544).
[I] Average over 10 runs is 0.22616 ms (host walltime is 0.306785 ms, 99% percentile time is 0.24064).
[I] Average over 10 runs is 0.231062 ms (host walltime is 0.311651 ms, 99% percentile time is 0.237568).
[I] Average over 10 runs is 0.221075 ms (host walltime is 0.299595 ms, 99% percentile time is 0.242656).
&&&& PASSED TensorRT.trtexec # ./trtexec_debug --deploy=/home/cding/tensorrt/TensorRT-5.1.5.0/data/mnist/deploy.prototxt --output=prob
line 2207 ~ 2212, there are some invalid “.”
Hi Chris,
I assume you use the deploy.prototxt from my comment. Because the text area has character limit, I can’t post the complete file, so I use … to skip partial file. Please refer to the dropbox link I attached.
In your link https://www.dropbox.com/sh/5m3muojw9n8hlyw/AACwDPE1iEnlnI59fjGl7Lk2a?dl=0
prototxt and caffemodel are OK.
./trtexec --deploy=/home/cding/tmp/deploy.prototxt --output=softmax --model=/home/cding/tmp/snapshot_iter_600.caffemodel
Yes. I was also able to test the model with nvcaffe. But when I deploy it to deepstream 4.0.1. I’m getting the errors (callstack in very first comment). I’m clueless.
Can you provide your nvinfer config and more deepstream deploy details ?
Hi Chris,
I don’t have the details with me. Basically I just override the caffemodel, deploy.prototxt and labels.txt from the primary infer config file of the resnet-10 example. The errors only affects the block_xxx/Scale layers, which makes me suspect it is the deepstream sdk problem. Could you try deploy on deepstream?
It’s not enough.
“model-engine-file” should be commented,
“output-blob-names” should be changed,
“network-mode” should be 0 if you does not do int8 calibration
Yes. I actually did all these steps. I set output-blob-names to softmax.
I will double check my config file when I get a chance.
Hi ben,
Could you run sucessfully with official caffe?
I got the following errors with officcial caffe when I ran test with your provided model and weights in dropbox.
./caffe test -model deploy.prototxt -weights snapshot_iter_600.caffemodel
There is the error log.
I1212 00:38:03.078389 53292 net.cpp:202] Conv2d_1a_3x3 does not need backward computation.
I1212 00:38:03.078395 53292 net.cpp:202] input does not need backward computation.
I1212 00:38:03.078402 53292 net.cpp:244] This network produces output softmax
I1212 00:38:03.079109 53292 net.cpp:257] Network initialization done.
I1212 00:38:03.232255 53292 upgrade_proto.cpp:79] Attempting to upgrade batch norm layers using deprecated params: /home/scratch.hhao_sw/repos/trt/build-lts-1-5.1-e7bb632fc8-V2/x86_64-linux/snapshot_iter_600.caffemodel
I1212 00:38:03.232364 53292 upgrade_proto.cpp:82] Successfully upgraded batch norm layers using deprecated params.
I1212 00:38:03.232376 53292 net.cpp:746] Ignoring source layer data
F1212 00:38:03.232399 53292 blob.cpp:496] Check failed: count_ == proto.data_size() (864 vs. 0)
*** Check failure stack trace: ***
@ 0x7f7d3159457d google::LogMessage::Fail()
@ 0x7f7d31596b33 google::LogMessage::SendToLog()
@ 0x7f7d3159410b google::LogMessage::Flush()
@ 0x7f7d31595a7e google::LogMessageFatal::~LogMessageFatal()
@ 0x7f7d31bbf5e8 caffe::Blob<>::FromProto()
@ 0x7f7d31cde24e caffe::Net<>::CopyTrainedLayersFrom()
@ 0x7f7d31ce30d5 caffe::Net<>::CopyTrainedLayersFromBinaryProto()
@ 0x409a5f test()
@ 0x407a4e main
@ 0x7f7d305b6830 __libc_start_main
@ 0x4083c9 _start
Yes. I tried with official caffe and got the same error.
My model trained on DIGITS which uses nvcaffe-19.10. I tested directly with nvcaffe-19.10 and worked. Chris also confirmed the model is okay. I believe nvcaffe is slightly different than official caffe on interpreting the model.
Hi ben,
I tried to run your model with nvidia caffe:19.11-py3, and it worked also. So I could come to the conclusion that this is caffe parser bug in TensorRT.
source file:
# Copyright (c) 2019 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
#type=4
#uri=file://../../streams/sample_1080p_h264.mp4
#uri=rtsp://10.234.8.61:50010/live?camera=15&user=admin&pass=A1crUF4%3D
#num-sources=1
#drop-frame-interval=2
#gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
#cudadec-memtype=0
type=5
camera-width=1280
camera-height=720
camera-fps-n=30
camera-fps-d=1
#camera-v4l2-dev-node=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_face.txt
[tracker]
enable=0
tracker-width=480
tracker-height=272
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for IOU only
#ll-config-file=iou_config.txt
gpu-id=0
[tests]
file-loop=0
primary inference config file:
[property]
gpu-id=0
net-scale-factor=1
model-file=/home/ben/Downloads/FaceNet/snapshot_iter_600.caffemodel
proto-file=/home/ben/Downloads/FaceNet/deploy.prototxt
labelfile-path=/home/ben/Downloads/FaceNet/labels.txt
batch-size=1
model-color-format=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
is-classifier=1
output-blob-names=softmax
I also suspect it is the caffe model parser issue.
I have a local quick fix of the TensorRT caffe parser issue.
This need to build TensorRT with TensorRT Open Source Software https://github.com/NVIDIA/TensorRT
Use the following modification.
https://github.com/NVIDIA/TensorRT/blob/master/parsers/caffe/caffeParser/opParsers/parseScale.cpp#L34
- Weights shift = !p.has_bias_term() || p.bias_term() ? (weightFactory.isInitialized() ? weightFactory(msg.name(), WeightType::kBIAS) : weightFactory.allocateWeights(C)) : weightFactory.getNullWeights();
+ // Caffe will learn bias only if bias_term is true.
+ // Otherwise bias is 0.
+ Weights shift = (p.has_bias_term() && p.bias_term())
+ ? (weightFactory.isInitialized() ? weightFactory(msg.name(), WeightType::kBIAS)
+ : weightFactory.allocateWeights(C))
+ : weightFactory.getNullWeights();
I will give it a shot. Thank you.
